29647 Discussions
No Stack Frame in VS2012 for Debugging
Ben3
I'm trying to debug an application in the VS2012 debugger but I can't work out how to get the stack frame to display. The call stack just lists things like "cm_mass.exe!<unknown function> Line 162", and it won't show me the contents of any variables. It does hit breakpoints fine and load the appropriate source files. This is the compiler command it's using:
[plain]ifort /nologo /debug:full /Od /QxSSE4.2 /fpp /I"C:\\Users\\bmenadue\\documents\\visual studio 2012\\Projects\\openMP Analysis\\libanalysis\\x64\\Debug" /Qopenmp-report1 /warn:all /debug-parameters:all /assume:byterecl /module:"x64\\Debug\\" /object:"x64\\Debug\\" /Fd"x64\\Debug\\vc110.pdb" /FAs /Fa"x64\\Debug\\" /traceback /check:all /libs:dll /threads /dbglibs /c /Qvc11 /Qlocation,link,"C:\\Program Files (x86)\\Microsoft Visual Studio 11.0\\VC\\bin\\amd64" "C:\\Users\\bmenadue\\Google Drive\\Code\\openMP Analysis\\trunk\\bin\\cm_mass.f90"[/plain]
It's definitely using /traceback and /debug:full with no optimisation. I was originally using openMP as well (and set the reentrancy using /reentrancy:threaded), but I removed them in case that was breaking the debugger (but it didn't help).
Ben
EDIT: Fixed the command line because the forum gobbled up the backslashes.
Seems to work ok for me in a sample project (not using OpenMP, though - that probably causes problems with examining variables as it can't see into the threads.)
