Hi all,
this is a question and a feature request just in case someone at Intel is interested.
The source below compiles without warnings, and fails at run-time. In my understanding, the code violates language rules (please correct me here, if I am wrong). It would therefore be neat if the compiler would issue a compile-time warning in situations like that; it took me quite some time to identify a similar issue.
Description:
The code contains an extended derived type (Child) which overwrites a type-bound procedure binding. However, the overwritten binding's (Child_sub) dummy argument (class(X)) characteristics differ from the overwritten binding (type(X)). The corresponding source lines are marked by an asterisk (*).
Terminal output:
ifort test.f90 -g -trace ./a.out forrtl: severe (174): SIGSEGV, segmentation fault occurred Image PC Routine Line Source a.out 0000000000403AF3 Unknown Unknown Unknown libpthread-2.27.s 00007F2987317890 Unknown Unknown Unknown a.out 0000000000402ADF m_mp_child_sub_ 25 test7.f90 a.out 0000000000402C71 MAIN__ 37 test7.f90 a.out 0000000000402A82 Unknown Unknown Unknown libc-2.27.so 00007F2986D31B97 __libc_start_main Unknown Unknown a.out 000000000040296A Unknown Unknown Unknown
Modification:
Swap type and class attributes in lines marked by (*).
Modification terminal output:
ifort test.f90
./a.out
7046112
Source "test.f90":
module m
type :: X
integer :: i = 1
end type
! Parent and Child
type :: Parent
contains
procedure, nopass :: sub => Parent_sub
end type
type, extends(Parent) :: Child
contains
procedure, nopass :: sub => Child_sub
end type
contains
! Parent subroutine
subroutine Parent_sub(a)
class(X) :: a ! (*)
end subroutine
! Child subroutine
subroutine Child_sub(a)
type(X) :: a ! (*)
print *, a%i
end subroutine
end module
program test
use m
implicit none
type(X) :: a
class(Parent), allocatable :: myChild
allocate(Child::myChild)
call myChild%sub(a)
end program
Details:
- Product Version: Intel(R) Fortran Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 19.0.3.199 Build 20190206
- Host OS and Version: Ubuntu 18.04.2 LTS Release: 18.04 Codename: bionic
Kind regards
Ferdinand
That is indeed an intel bug. nagfor and gfortran both complain, that
Argument A of overriding type-bound procedure SUB of type CHILD is not polymorphic
Thanks Juergen! I wish ifort had told me exactly that.
