(I know there's a few abstract type/inheritance issues floating outstanding, so apologies if this has already been reported.)
I think C429 in F2003 (C427 in F2008) means that the compiler should be giving me a good kicking for the following, but with 12.0.5 on IA32 (sorry for forgetting to specify that last time...) with /check:all /warn:all my transgressions pass unnoticed.
(I'm sure the compiler has picked me up on this before (?) - it sticks in my head because the reported location of the error was something daft like the first line of the file or the location of the parent type, rather than the location of the definition of the extension type.)
[fortran]PROGRAM AbstractlyConcrete
IMPLICIT NONE
TYPE, ABSTRACT :: abstract_type
CONTAINS
PROCEDURE(at_DeferredProc), DEFERRED :: DeferredProc
END TYPE abstract_type
ABSTRACT INTERFACE
SUBROUTINE at_DeferredProc(obj)
IMPORT :: abstract_type
IMPLICIT NONE
CLASS(abstract_type), INTENT(IN) :: obj
END SUBROUTINE at_DeferredProc
END INTERFACE
! oops, forgot ", ABSTRACT"...
TYPE, EXTENDS(abstract_type) :: still_abstract_type
END TYPE still_abstract_type
TYPE(still_abstract_type) :: look_mum_no_bindings
! CALL look_mum_no_bindings%DeferredProc ! Results in link error
END PROGRAM AbstractlyConcrete
[/fortran] (I'm sure the compiler has picked me up on this before (?) - it sticks in my head because the reported location of the error was something daft like the first line of the file or the location of the parent type, rather than the location of the definition of the extension type.)
You had me a bit confused at first with your constraint references until I realized that you had them reversed. It's C429 in F2008, C427 in F2003.
I agree that the compiler should give an error for this and I will let the developers know. Thanks. Issue ID is DPD200172982.
Tacked on here because I think its a consequence of the potential link error (which I think others have reported) in the previous example.
12.0.5 compiles and links this (as I think it should, despite the program not being terribly useful), but 12.1.0 gives a silly link error.
[fortran]MODULE Parents
IMPLICIT NONE
PRIVATE
TYPE, ABSTRACT, PUBLIC :: Parent
CONTAINS
PROCEDURE(which_the_linker_should_not_be_looking_for), DEFERRED :: Proc
END TYPE Parent
ABSTRACT INTERFACE
SUBROUTINE which_the_linker_should_not_be_looking_for(op)
IMPORT :: Parent
IMPLICIT NONE
CLASS(Parent), INTENT(IN) :: op
END SUBROUTINE which_the_linker_should_not_be_looking_for
END INTERFACE
END MODULE Parents
MODULE ATypes
USE Parents
IMPLICIT NONE
PRIVATE
TYPE, PUBLIC, EXTENDS(Parent) :: TypeA
CONTAINS
PROCEDURE :: Proc => a_Proc
END TYPE TypeA
CONTAINS
SUBROUTINE a_Proc(op)
CLASS(TypeA), INTENT(IN) :: op
END SUBROUTINE a_Proc
END MODULE ATypes
MODULE BTypes
USE Parents
IMPLICIT NONE
PRIVATE
TYPE, PUBLIC, EXTENDS(Parent), ABSTRACT :: TypeB
END TYPE TypeB
CONTAINS
SUBROUTINE sub
USE ATypes
CLASS(TypeA), ALLOCATABLE :: conn
ALLOCATE(TypeA:: conn)
END SUBROUTINE sub
SUBROUTINE sub2(op)
CLASS(TypeB), INTENT(IN) :: op
CALL op%Proc
END SUBROUTINE sub2
END MODULE BTypes
PROGRAM ThatIsRatherShort
IMPLICIT NONE
END PROGRAM ThatIsRatherShort
[/fortran] [plain]>ifort /check:all /warn:all /standard-semantics abstract-links.F90 Intel Visual Fortran Compiler XE for applications running on IA-32, Version 12.1.0.233 Build 20110811 Copyright (C) 1985-2011 Intel Corporation. All rights reserved. abstract-links.F90(30): remark #7712: This variable has not been used. [OP] SUBROUTINE a_Proc(op) --------------------^ Microsoft Incremental Linker Version 8.00.50727.762 Copyright (C) Microsoft Corporation. All rights reserved. -out:abstract-links.exe -subsystem:console abstract-links.obj abstract-links.obj : error LNK2001: unresolved external symbol _WHICH_THE_LINKER_SHOULD_NOT_BE_LOOKING_FOR abstract-links.exe : fatal error LNK1120: 1 unresolved externals[/plain]
The missing error as originally reported has been fixed in our sources. The fix will appear in a future release.
The linker error is one we have several reports on and we're working on it.
