Nonintegers in initialization expressions
Luke_R_
I've got a question concerning ifort warning messages. When I compile the following code:
[fortran]program test_numbers
  implicit none
  double precision, parameter :: pi = 3.141592653589793d+0
  double precision, parameter :: pi12 = sqrt(pi)
  double precision, parameter :: pi13 = pi**(1.d+0 / 3.d+0)
  write (*,*) "pi = ", pi
  write (*,*) "pi12 = ", pi12
  write(*,*) "pi13 = ", pi**(1.d+0 / 3.d+0)
end program test_numbers[/fortran]
Using "ifort -std03 test.F90" or "ifort -std08 test.F90", a get a warning
test.F90(5): warning #6187: Fortran 2003 requires an INTEGER data type in this context.
However, a Fortran standard allows the use of any data types in initialization expressions from 2003 and beyond, see 7.1.7(4) in http://www.j3-fortran.org/doc/year/04/04-007.pdf.
This is not a big problem, however, since my code is a part of a large project, other people might get worried about the warning messages they're getting. The flags "-std03" or "-std08" are used by the configure script of the code.
My question is: should ifort really cast a warning message for F2003 and F2008 standards in such a case?
Thanks a lot for your help.
Steven_L_Intel1
This is a F95 restriction that in exponentiation, the power had to be integer - we apparently missed noting that it was relaxed in F2003. I'll let the developers know - thanks.
Steven_L_Intel1
This has been fixed for a future release.
Luke_R_
Thanks a lot for your help!
