Not a valid win32 application
Wen_C_
Hi, I use Visual Studio 2013, Intel XE 2015 Fortran,  I complied a program using release mode and win32 platform.  When I ran this program in a Windows XP computer, I got an error "program.exe is not a valid win32 application".  Can anyone help ?  The project property page is attached.
Wen_C_
Steve,  Thanks, The only reason I am using Visual Studio 2013 is to use Intel Parallel Studio XE 2015 Fortran.  The only language I use is Fortran.  Can I compile the program using Intel Fortran only without Visual Studio ?  and how to do it ?  Thanks
You don't have to build the program in Visual Studio - you can do it from the command line, if you want. But debugging is in Visual Studio only.
To do it from the command line, open a Fortran build environment window using Start > Intel Parallel Studio XE 2015 > Compiler and Performance Libraries > Command Prompt with Intel Compiler XE 2015 > IA-32 (or Intel 64) Visual Studio 2013 mode.
The command to compile and link is "ifort". For example:
ifort myprog.f90
See the compiler documentation for more on using it from the command line. You will need to add:
/LINK /SUBSYSTEM:CONSOLE,"5.01"
to the end of the ifort command used to link if you want to run on XP.
