29383 Discussions
O3 optimization gives incorrect results for allocatable arrays and nested loops
KDob
I experienced a problem when usign -O3 optimization on code with nested loops acting on allocatable arrays. The following shows a minimal example of my code:
--->main.f90
program main
  use norms
  implicit none
  integer :: Nx,Ny,Nz
  complex, ALLOCATABLE, DIMENSION(:,:,:) :: arr
  real, ALLOCATABLE, DIMENSION(:) :: normParts1
  integer :: i,j
  Nx=4
  Ny=4
  Nz=4
  ALLOCATE(arr(Nx,Ny,Nz), normParts1(Nz))
  arr(1,1,1)=(1.D0,0.D0)
  arr(1,2,1)=(1.D0,0.D0)
  arr(4,4,1)=(1.D0,0.D0)
  write(*,*) norm(Nx,Ny,Nz,arr)
  CALL normParts(Nx,Ny,Nz,arr,NormParts1)
  write(*,*) NormParts1
end program main
--->norms.f90
module norms
  implicit none
contains
  function norm(Nx,Ny,Nz, arr)
    implicit none
    INTEGER, INTENT(IN) :: Nx,Ny,Nz
    COMPLEX, INTENT(IN) :: arr(Nx,Ny,Nz)
    REAL :: norm
    INTEGER :: i,j, k
    norm=0.D0
    do i=1,Nx
       do j=1,Ny
          do k=1, Nz
             norm=norm+abs(arr(i,j,k))**2
          end do
       end do
    end do
  end function norm
  subroutine normParts(Nx, Ny, Nz, arr, normParts1)
    IMPLICIT none
    REAL :: normParts1(Nz)
    INTEGER, INTENT(IN) :: Nx, Ny, Nz
    INTEGER:: i,j,k
    do k=1,Nz
       normParts1(k)=0.0d0
    end do
    !do k=1,Nz
       do i=1,Nx
          do j=1,Ny
             do k=1,Nz
             normParts1(k)=normParts1(k)+abs(arr(i,j,k))**2
          end do
       end do
    end do
  end subroutine normParts
end module norms
when compiled with composer_xe_2013_sp1.0.080 and -03, normParts gives an incorrect result: norm=3, normParts=(2,0,0,0).
When compiled with 02, or when interchanging the loop order, such that k is the outermost loop (which would indeed be more efficient) everything works fine and norm=3, normParts=(3,0,0,0).
Is there anything dangerous in my code that may lead to behavior? Can this behavior be expected or is there something weird about this?
Kevin_D_Intel
This appears to be a defect in the Composer XE 2013 SP1 initial release (pkg. 080) that you noted using. I don't have a specific internal tracking id that I can associate the incorrect results/behavior to but the defect appears to be fixed beginning with the Composer XE 2013 SP1 Update 2 (pkg. l_fcompxe_2013.1.2.144) release.
At your convenience, if you can upgrade to the Update 2 that should resolve the issue or you might consider upgrading to the latest Composer XE 2013 SP1 Update 3 (l_fcompxe_2013.1.3.174).
