OMP: error #101: out of heap memory
Ralph_Altenfeld
I am making my first tries using the OpenMP library
using Visual Studio and Intel Fortran 11.1.054.
I set the flag for OpenMP to -QOpenMP compile and
then launch the code. As a result I got the following
error:
How can I solve this problem?
Thank you for your help
Cheers
Antoine
TimP
It may be useful to have more information. I think you mean a run-time error.
For example, if running on XP 32-bit, do you have /3GB switch set in boot.ini?
heap-arrays compile switch is not good in combination with /Qopenmp.
Ralph_Altenfeld
Quoting tim18
I am using a 32 bit version of my code on a 64 bit machine. The unparallelized version of the code showed to work properly (I guess that the memory requirements are not that big, it should not have failed due to memory shortage). I switched off the heap array flag (/heap-arrays). The code is still not working and failing for the same reason (error #101)
Thank you
Antoine
Ralph_Altenfeld
Quoting tim18
Thank you
Antoine
I made further research concerning my problem and I found out that this problem can be
changed using the KMP_STACKSIZE environment variable.
When KMP_STACKSIZE is too small (32k) I still get the error 101.
When I set KMP_STACKSIZE too a very big value (256M) I get another error
OMP: error #136: Cannot create thread
OMP: system error #8: Not enough storage is available to process this command
Can one help me with this???
Thank you
Antoine
jimdempseyatthecove
how many hardware threads are available on this system?
Jim
TimP
The defaults for KMP_STACKSIZE are in the ifort help file (2MB for 32-bit compiler). That should be a clue that you would consider values such as 4MB. If you want to support many threads, staying with 32-bit software won't make sense.
rico_caldeira
Hey, Antonie.
I had the same problem and it was annoying me a lot!
My solved my problem by setting well the number of threads to use.
As i was defining it with the routine OMP_SET_NUM_THREADS(NTH), the Number NTH was coming from another routine and my program was not doing it well. When I set it manually to use 2 threads (OMP_SET_NUM_THREADS(2)) it worked well. The program was trying to set a large number of threadds before.
I dont know if it helps you. Anyway, it took me some time to discover.
bye,
Ricardo.
