Hi.
I've been trying to familiarise myself with some of the F2003 OO features in V11. However, I'm having trouble doing the basic job of adding 'methods' to a derived type. The CONTAINS statement doesn't appear to be implemented for derived types so I've used a procedure pointer.
The trouble is I have to initialise the derived type's field to the appropriate procedure in the main program itself. Am I missing something or doesn't this defeat the object (if you forgive the pun)?
Can anyone help with an example that 'properly' implements methods?
Cliff
You are correct that type-bound procedures, along with most of the OO stuff, is not in 11.0. That said, I don't understand the problem you're seeing. Can you show an example? What do you mean by "initialized"?
Hi Cliff
Check this thread:
http://software.intel.com/en-us/forums/showthread.php?t=61119
I think the discussion there is something you are trying to do. Since the type bound procedures are not supported yet, we have to use a tortuitous way of using procedure pointers. Still there is bug in the IVF compiler.
Note that IVF 11.0.066 still has the bug that I have reported. Through premier support I know that it is fixed in version 11.1 but we don't know when it would be available.
Abhi
