OOP help
Izaak_Beekman
New Contributor II
Note updated May 3 2010 2:35 EST (UTC -5)
In a module subroutine I define the the following variable:
[fortran]    CLASS(mesh_3d),         INTENT(inout) :: grid[/fortran]
The mesh_3d type is contained in a module accessed by USE association. (The use statement is in the module, before the contains statement after which the subroutine is defined)
[fortran]       SELECT TYPE (grid)
       TYPE IS (cart_mesh_3d)
       ...[/fortran]
If I insert the following code as the first executable line of my subroutine,
(I then do reference grid in the body of the select type statement) I get the following error:
[plain]/home/ibeekman/Sandbox/crocco/postprocessers/cartesian/FPPTC/trunk/src/modfileio.F90(83): remark #7712: This variable has not been used.   [GRID]
    SELECT TYPE (grid)
-----------------^[/plain]
If I move this down to a point in the subroutine after I have performed some operation referencing grid this warning/error goes away. Can anyone tell if I'm doing something wrong?
Further update:
Code needs to be compiled with -warn all
I have now attached reproducer example code. Compile with -warn all
It would help if you could provide a complete example, but.. That's an informational message, not an error, and you would get it only if -warn unused was in effect. It could be that the compiler is not properly noting the use in a SELECT TYPE as a "use" - I'll see if I can come up with a test case showing that and report it to the developers.
Izaak_Beekman
New Contributor II
Yup, sorry I just included a test case. I forgot about the -warn all flag when generating the reproducer code, but then suddenly remembered it, and got the reproducer working.
Thanks, but I managed to come up with one on my own. Escalated as issue DPD200154617.
bucky83
Is this "Sort Of Bug" going to be fixed any time soon?
It's no big deal, but it is annoying nonetheless.
Dario
Kevin_D_Intel
There's nothing in the internal tracking reportsuggesting afix on theimmediate horizon. I pingedDevelopment for status and will post an update when I hear from them.
This bug has been fixed for a release later this year.
