Oddly indexed Pointer array
mattsdad
I need to know if the pointer to the array called 'AA' in the code below will actuall reference the several 'AA' elements of the 'ex' array. (The compiler makes no complaints.)
TYPE symbol
REAL, POINTER :: arr(:) => NULL()
END TYPE symbol
TYPE
E
REAL :: AA, BB, CC
END TYPE E
TYPE
P
TYPE(E), ALLOCATABLE, DIMENSION(:) :: ex
END TYPE P
TYPE
Bod
TYPE(P) :: pro
END TYPE Bod
TYPE
(Bod), ALLOCATABLE, DIMENSION(:) :: body
REAL, POINTER :: AA(:), BB(:), CC(:)
TYPE(symbol) :: sym
REAL, POINTER :: pnt
ALLOCATE(body(MAXBODIES))
ALLOCATE(body(B)%pro%ex(MAX))
CALL init_ex(body(B)) ! ..%ex(I)%AA gets data here
AA => body(B)%pro%ex(:)%AA
CALL insert_array_in_symbol_table('AA', AA)
! passes AA as REAL, POINTER pt(:) and sets symb(I)%arr => pt
sym = getSymbol('AA')
pnt => sym%arr(N)
! where N is in 1..MAX
My concern is that the REAL array AAhas other data between itssequential elements. Will theAA pointer array still index to the expected data elements?
Will 'pnt'point to theexpected AA element?
I appologize in advance for the convoluted qu estion. I am writing a parser around this data structure, andI fealt that waiting till the parser is completelydone to get to a test would be a waste of time ifthepointer arraydoesn't work.
It should work. AA will point to noncontiguous data and will have a non-unit stride in its descriptor. I assume that the corresponding dummy argument of insert_array_in_symbol_table declares the argument as an assumed-shape array (:) and that an explicit interface is provided.
mattsdad
MADsblionel:
Yes
MADsblionel:
and Yes (by use of the module it is part of.)
