29376 Discussions
Once again ... Comilation fails for files with extensions different from .f90
abhimodak
Hi
I think this (issue) happened some time back, then it was fixed buthappens again with update 6; really frustrating considering how basic this is:
Even if the "user-file-extensions" such as (.f95) are defined through Tools --> Options, the compilation fails from VS. One can compile such files using command line with options such as -Tf and /free.
The default from VS project properties is Fortran --> Language --> Source File Format == Use file extension. This will cause compilation failure even if the extension, for example .f95, is defined as a free fromat file through Tools --> Options.
{I find that a work-around is explicitly specifying the Source File Format option for such files. This can be done for many files at once by selecting those files from the project tree --> Source Files, then right click and use properties. The compilation will then be successful with "Project properties" using defaults.}
Abhi
I can't reproduce this. Can you show me a screenshot of the Tools > Options > Intel Visual Fortran > General page and the build log that fails?
abhimodak
Hi Steve
I have attached two snapshots. I have already shown you that I have added the non-default extensions in a snapshot attached to another post (on broken syntax coloring).
Abhi
Ok - I can reproduce it in VS2010. The /free is not being supplied on the command line. Works in VS2008, though... I'll report it to the developers. Issue ID is DPD200173496.
This has been fixed for as future update (after updatde 7).
Actually, it was fixed in Update 7.
