One more structure constructor error
Sean_S_2
If you try to use a structure constructor to construct a type that extends from some other type, and you have an array section argument, you get an error like the following:
test_section_constructor.F90(18): error #6593: The number of expressions in a structure constructor differs from the number of components of the derived type   [FOO]
b = foo(a2(:,1)) ! Spurious error
compilation aborted for test_section_constructor.F90 (code 1)
This happens even when you only have one component and one argument to the structure constructor.
Here's the full test case:
program test_section_constructor
implicit none
type, abstract :: foo_base
end type foo_base
type, extends(foo_base) :: foo
   integer, allocatable :: a(:)
end type foo
type(foo) :: b
integer :: a1(2) = 0
integer :: a2(2,2) = 0
b = foo(a1)      ! OK
end program test_section_constructor
Kevin_D_Intel
I reproduced this error and forwarded to Development (under internal tracking id below) and will update the post regarding a fix.
(Internal tracking id: DPD200255191)
Sean_S_2
I've found that this also occurs with certain intrinsics as the argument, e.g. "spread".
Kevin_D_Intel
Ok, thank you for the new info. I added a note to the Developers regarding that.
Sean_S_2
It seems that this was addressed in 15.0.0
