OpenMP Offload Reduction help
jimdempseyatthecove
Having issues with reduction in offload region
!  GPUtest2.f90
module mod_GPUtest
real(8), allocatable :: CPUarray(:,:)
end module mod_GPUtest
program GPUtest2
    use omp_lib
    use mod_GPUtest
    implicit none
    real(8) :: T1, T2, sum
    integer :: i, j, nReps, nVecs
    nVecs = 1000000
    nReps = 100
    allocate(CPUarray(3,nVecs))
    call random_number(CPUarray)
    nReps = 1000
    T1 = omp_get_wtime()
    sum = 0.0_8
    do j=1,nReps
        do i=1,nVecs
            sum = sum + norm2(CPUarray(:,i))
        end do
    end do
    T2 = omp_get_wtime()
    print *,"CPUarray", sum, T2-T1
    sum = 0.0_8
    !$omp parallel do private(i) reduction(+:sum) num_threads(8)
    do j=1,nReps
        do i=1,nVecs
        end do
    end do
    !$omp end parallel do
    print *,"OpenMP CPUarray", sum, T2-T1
    sum = 0.0_8
    !$omp target teams distribute parallel do map(toFrom:sum) map(from:nReps,nVecs,CPUarray) reduction(+:sum)
    do j=1,nReps
        do i=1,nVecs
        end do
    end do
    !$omp end target teams distribute parallel do
    print *,"Target CPUarray", sum, T2-T1
end program GPUtest2
---- output ----
 CPUarray   960955364.535284        4.10575359989889
 OpenMP CPUarray   960955364.523428       0.650032500037923
 Target CPUarray  0.000000000000000E+000  0.114313300000504
Jim Dempsey
jimdempseyatthecove
Resolved the issue.
My issue was in understanding the perspective of the map clause.
I needed to use map(to:....)
to copy from the CPU's perspective, from the CPU to the GPU.
As opposed to the, from the  GPU's perspective  from the CPU to the GPU
Jim Dempsey
jimdempseyatthecove
Resolved the issue.
Jim Dempsey
