29647 Discussions
OpenMP reduction problem with custom defined operator
N_Netto
I've found a problem when trying to compile an OpenMP code with user defined type and operator.
I've been successful in producing the following toy code for reproduction purposes:
    type mytype
        real(8)     :: a, b
        integer(4)  :: c, d
    end type
    interface operator(.max.)
        module procedure :: max_mytype
    end interface
!$omp declare reduction (.max. : mytype : omp_out = omp_out .max. omp_in ) initializer ( omp_priv = mytype(0.,0.,0,0) )
    function max_mytype ( op1, op2 ) result ( ans )
    class(mytype), intent(in)    :: op1, op2
    type(mytype)                :: ans
    if ( op2%a > op1%a ) then
        ans%a  = op2%a
        ans%b  = op2%b
        ans%c  = op2%c
        ans%d  = op2%d
    else
        ans%a  = op1%a
        ans%b  = op1%b
        ans%c  = op1%c
        ans%d  = op1%d
    endif
    end function
 When I'm trying to create a parallel instance with this reduction operator, the compiler yields an internal error:
!$OMP PARALLEL DO default(none) private(thread) reduction(.max.:ermx)
    do i =1, 1000
        thread = omp_get_thread_num()
        ermx = mytype(1.0*thread,2.0*thread,thread,2*thread)
    end do
!$OMP END PARALLEL DO
Compiling with Intel(R) Visual Fortran Compiler 19.0.5.281 [Intel(R) 64]...
ToyErroMax.f90
C:\Users\nicolasrln\source\repos\ToyErroMax\ToyErroMax\ToyErroMax.f90(85): internal error: Please visit 'http://www.intel.com/software/products/support' for assistance.
[ Aborting due to internal error. ]
I've tried with other clauses first as well, like shared, copyin, firstprivate etc... none was allowed.
However, I've discovered that when the reduction clause is my first clause, the file compiles just fine:
!$OMP PARALLEL DO reduction(.max.:ermx) default(none) private(thread)
!!$OMP PARALLEL DO default(none) private(thread) reduction(.max.:ermx)! does not work
    do i =1, 1000
        ermx = error_convergence(1.0*thread,2.0*thread,thread,2*thread)
    end do
------ Build started: Project: ToyErroMax, Configuration: Debug|x64 ------
ToyErroMax.f90
Build log written to  "file://C:\Users\nicolasrln\source\repos\ToyErroMax\ToyErroMax\x64\Debug\BuildLog.htm"
ToyErroMax - 0 error(s), 0 warning(s)
Aside from the internal error thing, I should be allowed to put my reduction clause in any position in the omp declartion?
Thanks!
Ron_Green
I'll take a look at this and get a bug report going if I can reproduce the error.
Ron_Green
you should not have to split the clauses across 2 lines.  That is a compiler error.  Any Internal Compiler Error is a bug.  But since this is the 19.0 branch I would encourage you to try the 2021.1 compiler in beta in the oneAPI HPC Toolkit or a 19.1 compiler.
N_Netto
I'm not, actually, splitting (One line is actually commented). The only difference is the position of the reduction clause. If I put any other clause before a custom reduction, the compiler crashes.
I've tried with my 19.1.2 compiler as well (same results).
This code:
    do i =1, 1000
    end do
 Leads to:
1>------ Build started: Project: ToyErroMax, Configuration: Debug x64 ------
1>Linking...
1>Embedding manifest...
1>
1>Build log written to  "file://C:\Users\nicolasrln\source\repos\ToyErroMax\ToyErroMax\x64\Debug\BuildLog.htm"
1>ToyErroMax - 0 error(s), 0 warning(s)
========== Build: 1 succeeded, 0 failed, 0 up-to-date, 0 skipped ==========
But this:
!!$OMP PARALLEL DO reduction(.max.:ermx) default(none) private(thread)
    do i =1, 1000
    end do
Leads to this:
Compiling with Intel(R) Visual Fortran Compiler 19.1.2.254 [Intel(R) 64]...
ToyErroMax.f90
compilation aborted for C:\Users\nicolasrln\source\repos\ToyErroMax\ToyErroMax\ToyErroMax.f90 (code 1)
ToyErroMax - 1 error(s), 0 warning(s)
Thanks for your support!
Ron_Green
bug ID is CMPLRIL0-33295. It affects all newer versions of the compiler 19.1 and 2021.1Beta
Ron_Green
This bug was fixed in the ifort compiler in oneapi 2021.4 and is not present in the current 2022.x compilers.
