OpenMP syntax bug
fah10
The Intel Fortran compiler does not compile programs when variable names used within OpenMP copyprivate clauses start with 'do'
However, from the OpenMP standard, I see no reason why such variable names should be forbidden?!
Example:
program test
real :: dot
!$omp parallel private(dot)
!$omp single
dot = 1.0
!$omp end single copyprivate(dot)
!$omp end parallel
end program test
Compilation aborts with:
omp_copyprivate_syntax.F90(9): error #5082: Syntax error, found 'DO' when expecting one of: /
omp_copyprivate_syntax.F90(9): error #7982: Variables in the COPYPRIVATE list must be PRIVATE in the enclosing parallel region.
The trivial work-around is to rename the variable.
Xiaoping_D_Intel
Thanks for reporting the error. I have filed a bug report (Tracking ID: DPD200162297) and will keep you posted on its status.
Xiaoping Duan
Intel Customer Support
