Opening Fortran with Xcode
Seyhan_Emre_G_
I wanted open fortran by using xcode. I already spent a lot of time trying to understand what I am doing wrong. I am not able to figure it out. I checked the following website as well:
http://software.intel.com/sites/products/documentation/hpc/composerxe/en-us/2011Update/start/mac/for/comp/tutorial/co_m_ide1.htm
However, I am not able to work it.
My Xcode is version 4.6.3. My mac OS x is version 10.7.5. The fortran compiler is intel fortran composer xe 2013 for OS X student version.
When I go with the directions given in the link above, I see the following:
-Launch Xcode
-Create a new xcode project
-OS X -> Application ->Command Line tool->Next.
Product name: Hello
Type:C++
Uncheck automatic reference counting.
-Click next. Click Save.
-Move Main.cpp and Hello.1 to trash.
-File->New file->Fortran Fixed Format File.
I do not have Groups&Files under the Target group.
-Click on Targets-> Click on Build Rules.
-Click on Add Build Rule on the lower right.
-Under Process choose fortran source files.
-Under Using choose Intel Fortran Compiler XE 13.0 (Limited Feature).
Go to File.for. Enter the following:
    program Hello
    write(*,*) 'Hello'
    end program Hello
-Build.
I get the following error line by line:
line1 program Hello
error #5149: Illegal character in statement label field.
error #5118: First statement in file must not be continues
line 2 write(*,*) 'Hello'
error #5082: Syntax error, found CHARACTER_CONSTANT
line 3 end program Hello
error #5082: Syntax error, found END-OF-FILE when expecting one of <LABEL> <END-OF-STATEMENT>
mecej4
If you choose "Fixed Format File", you must type your Fortran source to match. Statements begin in column 7, etc.
Alternatively, choose "Free Format File" and give the file a name ending in .f90.
Seyhan_Emre_G_
Thank you very much for your reply. It worked. Do you know where I can find the format for "Fixed Format File". I normally use Microsoft Visual Studio on my Microsoft and I use the format with .for. Is .f90 faster than .for?
I tested one of my fortran codes by using .f90 on Xcode. I have faced several problems.
Normally C and !! do commenting. However, this time C is not commenting. Is it possible to comment multiple lines by using Xcode?
mecej4
A 'C' in column-1 designates the line as a comment, but only in fixed-format source.
For the rules of fixed-format and free-format source, see any Fortran text book, or in the Intel Fortran documentation->Language Reference->Program Elements and Source Forms.
You cannot have multi-line comments without each line being a comment (such as in C, where they are delimited by /* and */), but you can achieve the same effect using the preprocessor, using #if 0...#endif.
There should not be much difference in the speed of compiling free-format source versus fixed-format source.
I do not have a Macintosh, so I cannot comment about X-Code.
