Openmp internal compiler error v13
pat97269
Hi all,
I want to report a bug, when you try to compile the following example with -openmp you get catastrophic error (tried with intel v13.0.1, works on a v12.1.2)
If you remove the save statement or the gradf in argument then it compiles with no error.
module foo
contains
subroutine hess_grad_approx(gradf)
integer :: i
double precision,dimension(:),allocatable :: gradf
double precision,dimension(:),allocatable,save :: fe
fe(i)=1d0
gradf(i)=1d0
end subroutine
end module foo
thanks
Thanks for the nice example. I have escalated this as issue DPD200239791 and will update this thread with any progress.
