29641 Discussions
Operator overloading side-effects when using parameterized derived types
jwmwalrus
New Contributor II
Hi.
I know this is the less popular feature in the history of Fortran, but I somehow see its merits.
The following code
module itemmod
    use ISO_FORTRAN_ENV
    implicit none
    private
    save
    type, public :: item(ilen, k)
        integer, len :: ilen = 0
        integer, kind :: k = real32
        real(k) :: val = 0
        integer :: delta(2) = 0
    end type
    interface operator(+)
        module procedure item_PLUS_item
    end interface
    public operator(+)
    interface operator(*)
        module procedure scalar_TIMES_item
    end interface
    public operator(*)
    type(item(1)), parameter, public :: group1 = item(1)(1., [1, 0])
    type(item(2)), parameter, public :: group2 = item(2)(1., [0, 1])
contains
    subroutine assert_same_group(lhs, rhs)
        type(item(*)), intent(in) :: lhs
        type(item(*)), intent(in) :: rhs
        print*,'assert_lhs=',lhs, ',ilen=',lhs%ilen
        print*,'assert_rhs=',rhs, ',ilen=',rhs%ilen
        if (lhs%ilen /= rhs%ilen) error stop 'ilen mismatch'
        if (.not. all(lhs%delta == rhs%delta)) error stop 'delta mismatch'
    end subroutine
    function item_PLUS_item(lhs, rhs) result(res)
        type(item(lhs%ilen)) :: res
        call assert_same_group(lhs, rhs)
        res%val = lhs%val + rhs%val
        res%delta = lhs%delta
    end function
    pure function scalar_TIMES_item(lhs, rhs) result(res)
        real, intent(in) :: lhs
        type(item(rhs%ilen)) :: res
        res%val = lhs * rhs%val
        res%delta = rhs%delta
    end function
end module itemmod
use ISO_FORTRAN_ENV
use itemmod
implicit none
type(item(1)) :: x, v
type(item(2)) :: y, w
print*,'group1=',group1,', ilen=',group1%ilen
print*,'group2=',group2,' ilen=',group2%ilen
x = 5. * group1
print*,'x=',x, ', ilen=',x%ilen
y = 5. * group2
print*,'y=',y,', ilen=',y%ilen
print*, x+y
! v = group1
! print*,'v=',v, ', ilen=',v%ilen
! w = group2
! print*,'w=',w,', ilen=',w%ilen
! print*, v+w
end
Fails to pass the correct ilen parameter when used in the binary (plus operator) expression at line 71:
$ ifx -V -g -O0 items.f90 && ./a.out
Intel(R) Fortran Compiler for applications running on Intel(R) 64, Version 2024.1.0 Build 20240308
Copyright (C) 1985-2024 Intel Corporation. All rights reserved.
 Intel(R) Fortran 24.0-1472.3
GNU ld (GNU Binutils for Debian) 2.42
 group1=  0.0000000E+00           1           0 , ilen=           1
 group2=  0.0000000E+00           0           1  ilen=           2
 x=  0.0000000E+00           1           0 , ilen=           1
 y=  0.0000000E+00           0           1 , ilen=           2
 assert_lhs=  0.0000000E+00           1           0 ,ilen=           1
 assert_rhs=  0.0000000E+00           0           1 ,ilen=           1
delta mismatch
The assert_same_group subroutine call should have stopped with 'ilen mismatch', but the ilen value for the rhs argument is somehow lost during invocation (and the value shown is not even the default one).
If I comment out lines 67-71 and uncomment lines 73-77, I get correct results for the assert_same_group call, at the expense of not using the overloaded operator(*) :
 v=  0.0000000E+00           1           0 , ilen=           1
 w=  0.0000000E+00           0           1 , ilen=           2
 assert_rhs=  0.0000000E+00           0           1 ,ilen=           2
ilen mismatch
And also, in all the cases, with ifx, the constructor at lines 25-26 is misbehaving (i.e., not assigning anything to val). With ifort, val is assigned correctly.
Barbara_P_Intel
Thanks for reporting this. I filed a bug report, CMPLRLLVM-57787.
We'll let you know when the issues are fixed.
