Optimization bug in IFX 2024.1.0
mecej4
Test 52 of the venerable SLATEC library (www.netlib.org/slatec) fits a piecewise polynomial to data. The Fortran 77 sources for this test are contained in about 40 files, with about 20,000 lines of code. When one of the source files (BNDACC.f) is compiled with the current version of IFX (2024.1.0) with options /Qmkl /MD /standard-semantics /Ot, the test program fails.
The following reproducer is a drastically shortened derivative from those 40 files, and is less than 200 lines long. It can be built using IFORT, IFX, Gfortran, etc., and uses some BLAS routines.
program tbndacc
   implicit none
   integer, parameter :: Mdg = 12, Nb = 4, Mt = 5, Jt =3
   real :: G(Mdg,6) = 0.0
   integer :: Ip = 2, Ir = 4
   G(1,1:5) = (/   0.2,   21.0,   40.8,    4.7,    1.7 /)
   G(2,1:5) = (/  -3.1,  -41.2,  -30.9,   -0.9,   -4.6 /)
   G(3,1:5) = (/   0.5,   19.3,   33.3,    2.9,    8.0 /)
   G(4,1:5) = (/  11.1,   44.4,   11.1,    0.01,   18.0 /)
   G(5,1:5) = (/   6.8,   43.1,   16.7,    0.05,   24.7 /)
   call BndAcc(G,Mdg,Nb,Ip,Ir,Mt,Jt)
CONTAINS
   subroutine bndacc(G,Mdg,Nb,Ip,Ir,Mt,Jt)
      implicit none
      integer Ip, Ir, Jt, Mdg, Mt, Nb
      real G(Mdg,*), rho, zero
      integer i, ie, ig, k, kh, l, lp1, mh, mu, nbp1
      zero = 0.
      nbp1 = Nb + 1
      if ( Jt /= Ip ) then
         if ( Jt > Ir ) then
            do i = 1, Mt
               G(Jt + Mt - i,1:nbp1) = G(Ir + Mt - i,1:nbp1)
            end do
            ie = Jt - Ir
            do i = 1, ie
               G(Ir + i - 1,1:nbp1) = zero
            end do
            Ir = Jt
         end if
         mu = min(Nb-1,Ir-Ip-1)
         if ( mu /= 0 ) then
            do l = 1, mu
               k = min(L,Jt-Ip)
               lp1 = l + 1
               ig = Ip + l
               do i = lp1, Nb
                  G(ig,i - k) = G(ig,i)
               end do
               do i = 1, k
                  G(ig,nbp1 - i) = zero
               end do
            end do
         end if
         Ip = Jt
      end if
      mh = Ir + Mt - Ip
      kh = min(nbp1,mh)
      do i = 1, kh
         call h12(1,i,max(i+1,Ir-Ip+1),mh,G(Ip,i),1,rho,G(Ip,i+1),1,Mdg,nbp1-i)
      end do
      Ir = Ip + kh
      if ( kh >= nbp1 ) G(Ir-1,i:Nb) = zero
      print '(i3,4x,5es12.4)',(i,G(i,1:Nb+1), i = 3, 5)
      return
   end subroutine bndacc
   subroutine h12(Mode,Lpivot,L1,M,U,Iue,Up,C,Ice,Icv,Ncv)
      implicit none
      integer Ice, Icv, Iue, L1, Lpivot, M, Mode, Ncv
      real Up
      real C(*), U(Iue,*)
      real b, cl, clinv, one, sm, ul1m1
      integer i, i2, i3, i4, incr, j, kl1, kl2, klp, l1m1, mml1p2
      real, external :: sdot
      external saxpy, sswap
      one = 1.
      if ( 0 >= Lpivot .or. Lpivot >= L1 .or. L1 > M ) return
      cl = abs(U(1,Lpivot))
      do j = L1, M
         cl = max(abs(U(1,j)),cl)
      end do
      if ( cl <= 0 ) return
      clinv = one/cl
      sm = (U(1,Lpivot)*clinv)**2
      do j = L1, M
         sm = sm + (U(1,j)*clinv)**2
      end do
      cl = cl*sqrt(sm)
      if ( U(1,Lpivot) > 0 ) cl = -cl
      Up = U(1,Lpivot) - cl
      U(1,Lpivot) = cl
      if ( Ncv <= 0 ) return
      b = Up*U(1,Lpivot)
      if ( b < 0 ) then
         b = one/b
         mml1p2 = M - L1 + 2
         if ( mml1p2 > 20 ) then
            l1m1 = L1 - 1
            kl1 = 1 + (l1m1-1)*Ice
            kl2 = kl1
            klp = 1 + (Lpivot-1)*Ice
            ul1m1 = U(1,l1m1)
            U(1,l1m1) = Up
            if ( Lpivot /= l1m1 ) call sswap(Ncv,C(kl1),Icv,C(klp),Icv)
            do j = 1, Ncv
               sm = sdot(mml1p2,U(1,l1m1),Iue,C(kl1),Ice) + b
               call saxpy(mml1p2,sm,U(1,l1m1),Iue,C(kl1),Ice)
               kl1 = kl1 + Icv
            end do
            U(1,l1m1) = ul1m1
            if ( Lpivot == l1m1 ) return
            kl1 = kl2
         else
            i2 = 1 - Icv + Ice*(Lpivot-1)
            incr = Ice*(L1-Lpivot)
            do j = 1, Ncv
               i2 = i2 + Icv
               i3 = i2 + incr
               i4 = i3
               sm = C(i2)*Up
               do i = L1, M
                  sm = sm + C(i3)*U(1,i)
                  i3 = i3 + Ice
               end do
               if ( sm /= 0 ) then
                  sm = sm*b
                  C(i2) = C(i2) + sm*Up
                  do i = L1, M
                     C(i4) = C(i4) + sm*U(1,i)
                     i4 = i4 + Ice
                  end do
               end if
            end do
         end if
      end if
      return
   end subroutine h12
end program
The incorrect results, from IFX with some level of optimization enabled:
ifx /Qmkl /standard-semantics /nologo /Ot tbndacc.f90 & tbndacc
  3     -1.3336E+01 -5.9561E+01 -1.8384E+01 -3.3817E-02 -2.9315E+01
  4      1.1100E+01 -1.7026E+01 -7.4028E+00 -3.4349E-02 -8.2774E+00
  5      6.8000E+00  1.6941E+01 -4.2105E+00 -1.6629E-02 -8.3781E+00
The correct results from IFX (no optimization), Gfortran, etc.:
ifx /Qmkl /standard-semantics /Od /nologo tbndacc.f90 & tbndacc
  3     -2.3280E+01 -6.1367E+01 -1.2575E+01 -1.9373E-02 -2.2430E+01
  4      1.1100E+01 -3.4233E+01 -1.5701E+01 -4.1192E-02 -2.2017E+01
  5      6.8000E+00  2.7982E+01 -2.4215E+00 -2.2976E-02 -3.2010E+00
Ron_Green
I reduced this down considerably.  And found the DO loop that was unrolled improperly and causes the error.   Again, turning off unrolling OR using the DIR$ NOUNROLL directive on this 1 loop will work around it while I get a bug report going and get us a fix.
I also got MKL out of the free variables, so compilation is quite simple
program tbndacc
   implicit none
   integer, parameter ::  Nb = 4, Jt =3
   real :: G(12,6) = 0.0
   call BndAcc(G,Nb,Ip,Ir,Jt)
CONTAINS
   subroutine bndacc(G,Nb,Ip,Ir,Jt)
      implicit none
      integer Ip, Ir, Jt, Nb
      real :: G(12,*), zero
      integer i,ig, k, l, lp1, mu, nbp1
      integer :: temp_max
      zero = 0.
      nbp1 = Nb + 1
         mu = min(Nb-1,Ir-Ip-1) !..mu will equal 1
            do l = 1, mu
               k = min(L,Jt-Ip)
               lp1 = l + 1
               ig = Ip + l
! dir NOUNROLL will prevent unroll error dir$ NOUNROLL
               do i = lp1, Nb
               end do
               do i = 1, k
               end do
            end do
      print*, 'G(3,1:5)'
      print*, G(3,1:5)
      print*, "Should be"
      print*, "  19.30000       33.30000       2.900000      0.0000000E+00   8.000000"
      STOP
      return
end program
 and here is the build/run at O2 to show the error
 rm a.out ; ifx  -O2  repro.f90 ; ./a.out
 G(3,1:5)
   2.900000       2.900000       2.900000      0.0000000E+00   8.000000
 Should be
and no error at O1
rm a.out ; ifx  -O1  repro.f90 ; ./a.out
 G(3,1:5)
 Should be
 and no error at O2 if -unroll0
rm a.out ; ifx  -O2 -unroll0 repro.f90 ; ./a.out
 G(3,1:5)
 Should be
 and no error if I use DIR$ NOUNROLL on that loop
!dir$ NOUNROLL
               do i = lp1, Nb
               end do
 G(3,1:5)
 Should be
mecej4
If the argument lists are removed from the CALL to and the first line of subroutine BNDACC, and the corresponding local variable declarations in BNDACC are removed, the bug is no longer seen. All the current arguments are then available through host association.
Ron_Green
using llvm opt-bisect-limit I found the error is tied to loop unrolling optimization.  Now it could be that @mecej4 has found an error in our references to the arguments.  Try this,
/Qunroll:0
On my linux system when I disabled loop unrolling to 2 or less then I didn't see the error.
Ron_Green
program tbndacc
   implicit none
CONTAINS
      implicit none
      integer :: temp_max
      zero = 0.
      nbp1 = Nb + 1
            do l = 1, mu
               k = min(L,Jt-Ip)
               lp1 = l + 1
               ig = Ip + l
               do i = lp1, Nb
               end do
               do i = 1, k
               end do
            end do
      print*, 'G(3,1:5)'
      print*, G(3,1:5)
      print*, "Should be"
      STOP
      return
end program
 G(3,1:5)
 Should be
and no error at O1
 G(3,1:5)
 Should be
 G(3,1:5)
 Should be
!dir$ NOUNROLL
               do i = lp1, Nb
               end do
 G(3,1:5)
 Should be
Ron_Green
Bug ID is CMPLRLLVM-57523. Thank you for isolating this to a short reproducer. I helped me to quickly get to the root cause.
mecej4
Test 52 of SLATEC runs and reports "passed" if bndacc.f is compiled with IFX  /Qunroll:2 . Similarly, Test 53 (the double precision version of Test52) runs correctly if dbndac.f is compiled with /Qunroll:2.
Thanks for preparing and filing the IFX compiler error report.
Devorah_H_Intel
This issue has been fixed in the recently released Intel Fortran Compiler, available for download as part of Intel HPC Toolkit 2024.2.1
