Optimization issue: reallocation of array in a contained procedure not recognized.
FortranFan
With initial release of compiler 17.0, in code generated with the compiler optimization of /On where n>0, reallocation of array in a contained procedure does not seem to be recognized fully e.g., SIZE function result does not change.  /O0 works as expected.  I have not had a chance to try update 1 of 17.0 yet.
program p
   implicit none
   integer, parameter :: N = 1
   integer, allocatable :: foo(:)
   allocate( foo(N) )
   print *, "Before reallocation:"
   print *, "size(foo) = ", size(foo)
   call realloc()
   print *
   print *, "After reallocation:"
   stop
contains
   subroutine realloc()
      integer, allocatable :: tmp(:)
      allocate( tmp(2*N) )
      call move_alloc( from=tmp, to=foo )
      return
   end subroutine realloc
end program p
Upon execution with /On where n>0,
 size(foo) =  1
 After reallocation:
 size(foo) =  1
Johannes_Rieke
New Contributor III
Dear FortranFan,
I tested your code I could not reproduce the behavior with PSXE 2017 intitial and update 1 with /O3 in x32 and x64.
 size(foo) =            1
 After reallocation:
 size(foo) =            2
Strangely, I thought I had seen something like this in my code some days ago. I used reallocation (move_alloc) also and called this in a module contained subroutine and was wondering, why my control output missed some lines. At the end I figured out that it was gone after a clean rebuild (/O2 PSXE 2017 update 1, x64, old build was done with PSXE 2016 update3). Could this be caused by some objects mixed?
Hopefully it will work for you with update 1. Best regards, Johannes
Steven_L_Intel1
I can reproduce this in Update 1. I know I've reported this problem before but so far I can't locate the previous report. I'll keep looking.
Steven_L_Intel1
Ah, found it. That case works now, though - this one doesn't. Will investigate.
Steven_L_Intel1
Escalated as issue DPD200415640.
Johannes_Rieke
New Contributor III
Hi Steve,
can you share the condition, when this simple example fails? As shown above, I could not reproduce it, but you and FortranFan can. I can reproduce the test case results in the other thread where PSXE 17 initial fails and 17 update 1 works fine.
Under what circumstances occur this problem? I'm asking, because I use move_alloc massively in my projects and cannot test it in every case. To know when exactly DPD200415640 shows up would be very helpful and would let me sleep better ;-)
FortranFan
Johannes wrote:
.. Under what circumstances occur this problem? I'm asking, because I use move_alloc massively in my projects and cannot test it in every case. To know when exactly DPD200415640 shows up would be very helpful and would let me sleep better ;-) ..
@Johannes,
See this first!! http://www.searchquotes.com/search/Sleep_Is_Overrated/
With the example in the original post,
C:\..>ifort /O2 /standard-semantics /stand /warn:all p.f90
Intel(R) Visual Fortran Intel(R) 64 Compiler for applications running on Intel(R
) 64, Version 17.0.1.143 Build 20161005
Copyright (C) 1985-2016 Intel Corporation.  All rights reserved.
Microsoft (R) Incremental Linker Version 12.00.40629.0
Copyright (C) Microsoft Corporation.  All rights reserved.
-out:p.exe
-subsystem:console
p.obj
C:\..>p.exe
 size(foo) =  1
 After reallocation:
 size(foo) =  1
Johannes_Rieke
New Contributor III
Hi FortranFan,
thanks for your answer. Not that I sleep much, but sometimes it helps to defrag my brain ;-)
I can reproduce the error now, if I build from console with exactly your build instruction:
D:\02_Fortran\99_test\Realloc_PSXE17>ifort /O2 /standard-semantics /stand /warn:
all Realloc_PSXE17.f90
Microsoft (R) Incremental Linker Version 14.00.24215.1
-out:Realloc_PSXE17.exe
-subsystem:console
Realloc_PSXE17.obj
 size(foo) =  1
 After reallocation:
 size(foo) =  1
, but not if I build from VS2015 with:
Compiling with Intel(R) Visual Fortran Compiler 17.0.1.143 [Intel(R) 64]...
ifort /nologo /O2 /standard-semantics /warn:all /module:"x64\Release\\" /object:"x64\Release\\" /Fd"x64\Release\vc140.pdb" /libs:static /threads /c /stand /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\\bin\amd64" /Qm64 "D:\02_Fortran\99_test\Realloc_PSXE17\Realloc_PSXE17.f90"
Linking...
Link /OUT:"x64\Release\Realloc_PSXE17.exe" /INCREMENTAL:NO /NOLOGO /MANIFEST /MANIFESTFILE:"x64\Release\Realloc_PSXE17.exe.intermediate.manifest" /MANIFESTUAC:"level='asInvoker' uiAccess='false'" /SUBSYSTEM:CONSOLE /IMPLIB:"D:\02_Fortran\99_test\Realloc_PSXE17\x64\Release\Realloc_PSXE17.lib" -qm64 "x64\Release\Realloc_PSXE17.obj"
Embedding manifest...
mt.exe /nologo /outputresource:"D:\02_Fortran\99_test\Realloc_PSXE17\x64\Release\Realloc_PSXE17.exe;#1" /manifest "x64\Release\Realloc_PSXE17.exe.intermediate.manifest"
Realloc_PSXE17 - 0 error(s), 0 warning(s)
 Before reallocation
 size(foo) =  1
 After reallocation:
 size(foo) =  2
Strange. I also run the VS build instruction in the shell and I can reproduce the error too (ifort /nologo /O2 /standard-semantics /warn:all /libs:static /threads /c /stand /Qm64 Realloc_PSXE17.f90 path stuff removed). Where is the difference and why fails the console build?
andrew_4619
For what it is worth I also get the same output as #7 in both 32 and 64 bit builds.
andrew_4619
program p
   implicit none
   allocate( foo(N) )
   call realloc()
   print *
   foo(1)=1
   foo(2)=2
   print *, "foo = ", foo
   print *, "foo(1), foo(2) = ", foo(1), foo(2)
   stop
contains
      return
end program p
!******output*******
! Before reallocation:
! size(foo) =  1
! After reallocation:
! size(foo) =  1
! foo =  1
! foo(1), foo(2) =  1 2
For what it is worth it is not just SIZE that is wrong the whole array op to write foo also fails so I assume there will be a host of consequential failures as a result of this bug.
Steven_L_Intel1
It's an optimization that is failing - it thinks that the descriptor isn't changing in the subroutine but it is. Like most optimization bugs, it won't show up in all programs that do this sort of thing.
Steven_L_Intel1
I am told that this bug has been fixed and that the fix should appear in Update 2 to Parallel Studio XE 2017.
FortranFan
Thanks for the feedback Steve.
