Optimization with o3
Alessandro_D_
Dear Forum Users,
I'm trying to run my Fortran code with /O3 enabled for speed.
In Properties > Fortran > General I change the following settings:
1) Optimization: max speed plus higher level optimization (/O3)
2) Debug information format: None
Then I press "Start without debugging"
Unfortunately I get the message
warning #10182: disabling optimization; runtime debug checks enabled
The code runs, but without optimization
Can someone please explain what's wrong here? Thanks
Best,
Alessandro
Xiaoping_D_Intel
What I mean you have two options for testing "-O3":
1. Continue to test -O3 in debug build but you need turn off "/check stack" in the project properties.
Or
2. Test -O3 in release build which has "/check stack" turned off by default. (I recommend this one).
What you did is checking the "Release" build setting of "Check Stack Frame" (Showed in your screenshot) but still building your code with "Debug" build (Showed in your build log). So please make sure to select "Debug"  at the left top of the project properties when you want to change the setting for "Debug" build.
Xiaoping Duan
Intel Customer Support
andrew_4619
Do a full build and post the build log
Alessandro_D_
Here is the log
<HTML><HEAD><meta content="text/html; charset=utf-16" http-equiv="Content-Type"></HEAD><BODY><PRE></pre><table width=100% bgcolor=#E0E0E0><tr><td><font face=arial size=+2> Build Log </font></table><table width=* cellspacing=0 cellpadding=0><tr><td width=0 bgcolor=#E0E0E0>&nbsp;</td><td width=0 bgcolor=white>&nbsp;</td><td width=*><pre><h3> Build started: Project: test, Configuration: Debug|Win32 </h3></pre></table><table width=100% bgcolor=#E0E0E0><tr><td><font face=arial size=+1> Output </font></table><table width=* cellspacing=0 cellpadding=0><tr><td width=0 bgcolor=#E0E0E0>&nbsp;</td><td width=0 bgcolor=white>&nbsp;</td><td width=*><pre>Compiling with Intel(R) Visual Fortran Compiler 16.0 [IA-32]...
ifort /nologo /O3 /warn:interfaces /module:&quotDebug\\&quot /object:&quotDebug\\&quot /Fd&quotDebug\vc140.pdb&quot /traceback /check:bounds /check:stack /libs:dll /threads /dbglibs /c /Qlocation,link,&quotC:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\\bin&quot &quotC:\Dropbox\PROJECTMARIA\SHARED\codes and data\Fortran files\Source Codes\new_v6_sub1\toolbox.f90&quot
ifort: warning #10182: disabling optimization; runtime debug checks enabled
C:\Dropbox\PROJECTMARIA\SHARED\codes and data\Fortran files\Source Codes\new_v6_sub1\toolbox.f90(2508): warning #6843: A dummy argument with an explicit INTENT(OUT) declaration is not given an explicit value.
    function uniformCDF_Inv(x, a, b)
C:\Dropbox\PROJECTMARIA\SHARED\codes and data\Fortran files\Source Codes\new_v6_sub1\toolbox.f90(2459): warning #6843: A dummy argument with an explicit INTENT(OUT) declaration is not given an explicit value.
    function uniformCDF(x, a, b)
C:\Dropbox\PROJECTMARIA\SHARED\codes and data\Fortran files\Source Codes\new_v6_sub1\toolbox.f90(2412): warning #6843: A dummy argument with an explicit INTENT(OUT) declaration is not given an explicit value.
    function uniformPDF(x, a, b)
ifort /nologo /O3 /warn:interfaces /module:&quotDebug\\&quot /object:&quotDebug\\&quot /Fd&quotDebug\vc140.pdb&quot /traceback /check:bounds /check:stack /libs:dll /threads /dbglibs /c /Qlocation,link,&quotC:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\\bin&quot &quotC:\Dropbox\PROJECTMARIA\SHARED\codes and data\Fortran files\Source Codes\new_v6_sub1\mod_baselib.f90&quot
ifort /nologo /O3 /warn:interfaces /module:&quotDebug\\&quot /object:&quotDebug\\&quot /Fd&quotDebug\vc140.pdb&quot /traceback /check:bounds /check:stack /libs:dll /threads /dbglibs /c /Qlocation,link,&quotC:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\\bin&quot &quotC:\Dropbox\PROJECTMARIA\SHARED\codes and data\Fortran files\Source Codes\new_v6_sub1\mod_param.f90&quot
ifort /nologo /O3 /warn:interfaces /module:&quotDebug\\&quot /object:&quotDebug\\&quot /Fd&quotDebug\vc140.pdb&quot /traceback /check:bounds /check:stack /libs:dll /threads /dbglibs /c /Qlocation,link,&quotC:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\\bin&quot &quotC:\Dropbox\PROJECTMARIA\SHARED\codes and data\Fortran files\Source Codes\new_v6_sub1\main.f90&quot
ifort /nologo /O3 /warn:interfaces /module:&quotDebug\\&quot /object:&quotDebug\\&quot /Fd&quotDebug\vc140.pdb&quot /traceback /check:bounds /check:stack /libs:dll /threads /dbglibs /c /Qlocation,link,&quotC:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\\bin&quot &quotC:\Dropbox\PROJECTMARIA\SHARED\codes and data\Fortran files\Source Codes\new_v6_sub1\sub_write.f90&quot
ifort /nologo /O3 /warn:interfaces /module:&quotDebug\\&quot /object:&quotDebug\\&quot /Fd&quotDebug\vc140.pdb&quot /traceback /check:bounds /check:stack /libs:dll /threads /dbglibs /c /Qlocation,link,&quotC:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\\bin&quot &quotC:\Dropbox\PROJECTMARIA\SHARED\codes and data\Fortran files\Source Codes\new_v6_sub1\sub_howard.f90&quot
ifort /nologo /O3 /warn:interfaces /module:&quotDebug\\&quot /object:&quotDebug\\&quot /Fd&quotDebug\vc140.pdb&quot /traceback /check:bounds /check:stack /libs:dll /threads /dbglibs /c /Qlocation,link,&quotC:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\\bin&quot &quotC:\Dropbox\PROJECTMARIA\SHARED\codes and data\Fortran files\Source Codes\new_v6_sub1\sub_dist.f90&quot
ifort /nologo /O3 /warn:interfaces /module:&quotDebug\\&quot /object:&quotDebug\\&quot /Fd&quotDebug\vc140.pdb&quot /traceback /check:bounds /check:stack /libs:dll /threads /dbglibs /c /Qlocation,link,&quotC:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\\bin&quot &quotC:\Dropbox\PROJECTMARIA\SHARED\codes and data\Fortran files\Source Codes\new_v6_sub1\sub_vfi.f90&quot
ifort /nologo /O3 /warn:interfaces /module:&quotDebug\\&quot /object:&quotDebug\\&quot /Fd&quotDebug\vc140.pdb&quot /traceback /check:bounds /check:stack /libs:dll /threads /dbglibs /c /Qlocation,link,&quotC:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\\bin&quot &quotC:\Dropbox\PROJECTMARIA\SHARED\codes and data\Fortran files\Source Codes\new_v6_sub1\sub_read.f90&quot
ifort /nologo /O3 /warn:interfaces /module:&quotDebug\\&quot /object:&quotDebug\\&quot /Fd&quotDebug\vc140.pdb&quot /traceback /check:bounds /check:stack /libs:dll /threads /dbglibs /c /Qlocation,link,&quotC:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\\bin&quot &quotC:\Dropbox\PROJECTMARIA\SHARED\codes and data\Fortran files\Source Codes\new_v6_sub1\sub_plot.f90&quot
Linking...
Link /OUT:&quotDebug\test.exe&quot /INCREMENTAL:NO /NOLOGO /MANIFEST /MANIFESTFILE:&quotDebug\test.exe.intermediate.manifest&quot /MANIFESTUAC:&quotlevel='asInvoker' uiAccess='false'&quot /DEBUG /PDB:&quotC:\Dropbox\PROJECTMARIA\SHARED\codes and data\Fortran files\Source Codes\new_v6_sub1\test\Debug\test.pdb&quot /SUBSYSTEM:CONSOLE /IMPLIB:&quotC:\Dropbox\PROJECTMARIA\SHARED\codes and data\Fortran files\Source Codes\new_v6_sub1\test\Debug\test.lib&quot &quotDebug\toolbox.obj&quot &quotDebug\mod_baselib.obj&quot &quotDebug\mod_param.obj&quot &quotDebug\main.obj&quot &quotDebug\sub_write.obj&quot &quotDebug\sub_howard.obj&quot &quotDebug\sub_dist.obj&quot &quotDebug\sub_vfi.obj&quot &quotDebug\sub_read.obj&quot &quotDebug\sub_plot.obj&quot
Embedding manifest...
mt.exe /nologo /outputresource:&quotC:\Dropbox\PROJECTMARIA\SHARED\codes and data\Fortran files\Source Codes\new_v6_sub1\test\Debug\test.exe;#1&quot /manifest &quotDebug\test.exe.intermediate.manifest&quot
test - 0 error(s), 13 warning(s)
</PRE></BODY></HTML>
Xiaoping_D_Intel
The debug build has "/check stack" turned on which will disables optimization and overrides any optimization level set by option O. Suggest you do the O3 testing with the release build.
Xiaoping Duan
Alessandro_D_
Thanks but how can I turn off "/check stack"?
Xiaoping_D_Intel
Go to "Project Properties -> Fortran -> Runtime -> Check Stack Frame" and select "No".
It is turned off by default for release build.
Xiaoping Duan
Alessandro_D_
I did as you suggested but it doesn't work
In particular, in Project Properties I selected "Configuration: Release" and I made sure that
check stack frame is NO (this is indeed the default option for Release)
However I still get the same mistake
I write below the build log. I also attach a screenshot with the project properties
Linking...
Link /OUT:&quotDebug\test.exe&quot /INCREMENTAL:NO /NOLOGO /MANIFEST /MANIFESTFILE:&quotDebug\test.exe.intermediate.manifest&quot /MANIFESTUAC:&quotlevel='asInvoker' uiAccess='false'&quot /DEBUG /PDB:&quotC:\Dropbox\PROJECTMARIA\SHARED\codes and data\Fortran files\Source Codes\new_v6_sub1\test\Debug\test.pdb&quot /SUBSYSTEM:CONSOLE /IMPLIB:&quotC:\Dropbox\PROJECTMARIA\SHARED\codes and data\Fortran files\Source Codes\new_v6_sub1\test\Debug\test.lib&quot &quotDebug\toolbox.obj&quot &quotDebug\mod_param.obj&quot &quotDebug\mod_baselib.obj&quot &quotDebug\sub_plot.obj&quot &quotDebug\sub_vfi.obj&quot &quotDebug\main.obj&quot &quotDebug\sub_write.obj&quot &quotDebug\sub_read.obj&quot &quotDebug\sub_dist.obj&quot &quotDebug\sub_howard.obj&quot
test - 0 error(s), 1 warning(s)
Alessandro_D_
here
Xiaoping_D_Intel
The build log shows you are building the "Debug" build so please make sure you change the setting of "Debug" configuration.
Xiaoping Duan
Alessandro_D_
I don't understand, if you look at the screenshot that I attached you can see that I selected "Configuration: Release"
Xiaoping_D_Intel
Or
Xiaoping Duan
CTOptimizer
You also still have bounds checking turned on.  You can disable via the same project properties.
It still isn't clear whether you are building "Release" or "Debug" configuration.  What Xiaoping is seeing is that, your linker message above is showing that the executable being created is "\Debug\test.exe".
While you may have changed these settings in the properties for the "Release" builds, the build logs you have posted above appear to be for the Debug build.
I suspect you may have tried to use "-O3" by altering the "Debug" configuration.  This is likely since the "stack" and "bounds" checks are only enabled (by default) for Debug builds.  Please double check that you are selecting and building (and running) the "Release" configuration, and be sure those (debug) runtime checks are not enabled for the Release build.
Mark
