Out of memory error
meow
While compiling I get the following error:
FATAL COMPILATION ERROR: OUT OF MEMORY 32776
The program consists of many subroutines. I tried to make shorter subroutines but the problem persists.
The computer is a Xeon 5160, 64 bit, with 16 GB of RAM. This problem does not happen when I use the debug option; only when I use the release option.
Any idea why this is happening and how to fix it?
Pablo
Steven_L_Intel1
Please submit a report to Intel Premier Support and attach a ZIP of your project in the state after a build. There can be many possible reasons for this, but most likely the optimizer ran out of memory. This can happen more if you use /Qipo or /O3 options. It may help if you split the long files into several shorter files with different sets of routines.
