PCA - Fortran IV Program
JohnNichols
Honored Contributor I
I was playing with an old Fortran IV program - PCA from Wahlstedt and Davis - Kansas Geological Survey,  they have an equivalence statement at the beginning, but the program does not work with this statement in.
has the meaning of equivalence changed.  I have checked the results with new data.
This is the code as I currently have it:
!  PCA.f90
    !  FUNCTIONS:
    !  PCA - Entry point of console application.
    !  PROGRAM: PCA
    !  PURPOSE:  Entry point for the console application.
    program PCA
    use Base
    implicit none
    Integer M,N
    LOGICAL TEST, OPDAT, THERE
    CHARACTER*10 LABEL(mn,4)
    Character*10 Title(20),FMT(mn_12)
    Integer manual
    Integer astat
    Integer L
    Integer IVX
    Integer i
    Integer J
    Integer k
    Integer EN
    REAL (KIND=dp) :: X(ml,nn), SSD(mn,mn)
    REAL (KIND=dp) :: SX(mn), SD(mn),PERCON(mn)
    REAL (KIND=dp) :: SS(mn,mn), R(mn,mn),COVMAT(mn,mn)
    COMMON / WJ/ M,N, X,SSD,Title
    !EQUIVALENCE (SSD(1,1), SS(1,1),SX(1), PERCON(1))
    inquire(file = "data.in", EXIST = THERE)
    if(there) then
        open(8,file="data.in",status = "UNKNOWN", IOSTAT = astat)
    else
        stop 'NO file'
    end if
500 READ (8, *, ERR = 5000, END = 5000) M, MANUAL,OPDAT
    write(*,5010) M, MANUAL, OPDAT
5010 Format("         Data Reflection ::",/,"         M            :: ",I4,/,"         Manual       :: ",I4,/,"         OP DATA      :: ",L4)
    IF(M .le. 0) then
        CALL EXITM()
    end if
    do 103 L = 1,M
        read(8,*, ERR = 5000, END = 5000)(LABEL(L,IVX),IVX = 1,4)
103 end do
    do 100 i = 1,M
        SX(i) = ZERO
        do 201 j = 1,M
            SS(i,j) = ZERO
201     end do
100 end do
    READ (8, 10) TITLE
10  Format(20A4)
    READ (8,10)FMT
    Write(*,1000)TITLE
1000 Format(9x,20A4,/)
    SX = ZERO
    SS = ZERO
    N = 0
    do 16 n=1,300
        read(8,*)(x(n,j),j=1,M),TEST
        write(*,310)n,(x(n,j),j=1,M)
310     Format("      ",I4,5("    ",F8.2))
        do 20 i=1,M
            SX(i) = SX(i)+X(N,i)
            do 25 j = 1,M
                SS(I,j) = SS(i,j)+X(n,i)*X(n,j)
25          end do
20      end do
        write(*,310)N,(SX(i),i=1,M)
        if(TEST) then
            goto 26
        end if
16  end do
    write(*,*)"To many data points"
    call exitM()
26  write(*,27)N
27  Format(//"         Number of data points :: ", I4)
    If(OPDAT) THEN
        go to 1643
    end if
    write(*,1002)
1002 Format(//"------------------------------------------------------------",//,"         Input Data",/)
    do 101 i = 1,N
        write(*,1003) I
1003    Format("         Sample Number :: ",i4)
101 End do
1643 EN = N
    do 30 i = 1,M
        do 30 j = 1,M
            SSD(I,J) = (SS(i,j)-(sx(i)*SX(J))/float(EN))/(float(EN) - 1.0D0)
            COVMAT(I,J) = SSD(I,J)
30  end do
    Do 35 I = 1,M
        SD(I) = SQRT(SSD(I,I))
        SX(I) = SX(I)/FLOAT(EN)
35  end do
    Write(*,1000)Title
    Write(*,1005)M,N
1005 Format("         Number of variables    :: ",I4,/,"         Number of data points  :: ", I4,///,"          Variable          Mean       Standard Deviation")
    do 102 I =1,M
        write(*,1001)i,SX(I),SD(I)
102 end do
1001 Format(10x,I4,2(5x,f15.6))
    do 60 i=1,M
        do 61 j = 1,M
            R(I,J) = SSD(I,J)/(SD(I)*SD(J))
61      end do
60  end do
    if(MANUAL .eq. 2) then
        write(*,*)"          You have selected the Manual = 2 option"
        goto 72
    end if
72  if(MANUAL .eq. 1) then
        write(*,*)"          You have selected the Manual = 1 option"
        goto 500
    end if
    write(*,73)
73 Format(//"          You have selected the Manual = 3 option",/)
    stop 'End of Program'
5000 Stop 'File input error'
    end program PCA
    subroutine exitM()
    implicit none
    STOP " EXIT SUBROUTINE"
    return
    end subroutine
 Module Base
    INTEGER, PARAMETER :: dp = selected_real_kind(15, 307)
    INTEGER, PARAMETER :: sw = 2, srA = 1, st = 11, sa = 3, sm = 4, sc = 12, sRT = 25
    Integer, parameter :: slog = 9, sOUT = 10, sCAD = 21, sINI = 13, sWULF = 18
    Integer, parameter :: array_size = 3000
    integer, parameter :: nt = 2000
    integer, parameter :: mt = 2000        !   Number of members
    integer, parameter :: mn = 30
    integer, parameter :: ml = 300
    integer, parameter :: mn_12 = 12
    integer, parameter :: mn_4 = 4
    integer, parameter :: count1 = 20000
    integer, parameter :: nn = 5
    integer :: readFlag = 0
    REAL (KIND=dp) :: g = 9.806, pi = 3.14159265D0
    REAL (KIND=dp) :: delta = 0.000000000001d0
    REAL (KIND=dp) :: h = 0.0005d0
    REAL (KIND=dp) :: alpha = 0.16666d0
    REAL (KIND=dp) :: beta = 0.25d0
    REAL (KIND=dp) :: gamma = 0.5d0
    REAL (KIND=dp) :: ONE = 1.0d0
    REAL (KIND=dp) :: SMALLMASS = 0.001d0
    REAL (KIND=dp) :: TWO = 2.0d0
    REAL (KIND=dp) :: ZERO = 0.0d0
    REAL (KIND=dp) :: DAMPRATIO = 100.0d0
    REAL (KIND=dp) :: RATIO1 = 0.45d0
    REAL (KIND=dp) :: MULTIPLER = 0.4d0
    REAL (KIND=dp) :: RATIO2 = 0.25d0
    REAL (KIND=dp) :: SuggestG = 0.0d0
    contains
    end module Base
cryptogram
Reminds me of the first IBM PCs, which had 8x8 character pattern tables built into the BIOS that were used to create characters when running the display adapter in graphics modes.
GVautier
New Contributor III
 Clearer way and maybe faster
   select case (C)
   case("0":"9")
        num = ichar(C)-ichar("0")
   case("A":"F")
        num = ichar(C)-ichar("A")+10
   case("a":"f")
        num = ichar(C)-ichar("a")+10
   case default
        num = 0
    end select
JohnNichols
Thanks, that worked a treat.  My long one had a mistake, I had translated the 3 hexadecimal to 4 decimal.  It took a while to find the error.
This C method was developed for printing for the Arduino, but it is pretty easy to use in Fortran.
The fonts are a bit scratchy, but that is easy to fix.  The pictures shows the bitmap and the output to a BMP file.
GVautier
New Contributor III
Have you tried
      read(font(k)%dataS(L),'(Z2)')font(k)%num(L)
in place of
      A = font(k)%dataS(L)(1:1)
      B = font(k)%dataS(L)(2:2)
      call numH(A,B,font(k)%num(L))
JohnNichols
i thought about that,  but rather than speed I wanted understanding when I come back in several months.
