PCL codes
tmcole
A program that I have sends PCL codes to an output file that changes fonts, orientation, etc. This has worked for years. I even went to the trouble to provide an input to the program that allows the user to specify what type of laserjet printer they were using starting with the now ancient LJII.
Now, however, when I print the output, none of the PCL codes are interpreted by the printer (I have tried several different kinds of printers with no luck). I don't know how long it has been since this feature stopped working as I have not printed the output in a long time. My question is, has anyone done something similar in IVF/CVF and, if so, is it still working? If it is working, can you post or send me the code so I can test it out? Thanks.
