29423 Discussions
PGO with slightly different source code than was used to generate profiles
gregfi04
I'm in the final stages of testing a code, and I found typos in a couple of the error messages. Can I just do a recompile with PGO using the old profiles, or do I need to regenerate the profile data?
Greg
If you just changed the text of a character string, you won't need to redo the profiles. But if you change the logic of the program, you would.
gregfi04
Great, thanks. If logic were changed, would the compiler be smart enough to detect a mismatch? If not, could it potentially cause problems?
It might, if the number of "basic blocks" of code paths changed. If it didn't, the results could mislead the compiler into making optimization choices it shouldn't.
