29653 Discussions
POINTER attribute and Generic Interfaces
russell66
I have a generic Interface for a set of functions, some of which differ only by one argument having the POINTER attribute, as opposed to having the INTENT(IN) attribute..
under What conditions should the POINTER Function be
called? From what I am seeing, it isn't.
example Code:
INTERFACE WrDbgArray
MODULE PROCEDURE WrReal1dArray
MODULE PROCEDURE WrReal1dPtrArray
MODULE PROCEDURE WrReal2dArray
END INTERFACE
SUBROUTINE WrReal1DArray(name,array, idbg)
CHARACTER(LEN=*), INTENT(IN) :: name
REAL(sdk), DIMENSION(:), INTENT(IN) :: array
INTEGER(sik), INTENT(IN) :: idbg
SUBROUTINE WrReal1DPtrArray(name,array, idbg)
REAL(sdk), DIMENSION(:), POINTER :: array
Should this be a syntax error???
The code using this compiles and runs, but ALWAYS chooses
WrReal1dArray for 1d arrays...
What compiler and version are you using? CVF 6.6A disallows this - the generic is ambiguous. Neither POINTER nor INTENT are distinguishing characteristics of a generic procedure.
Steve
russell66
This is CVF 6.6A-
no syntax Error... the files are attached - simplified to minimize dependencies. IntrTypeM.f90 defines portable
INTEGER and REAL types, DebugUtilSimplifiedM.f90 contains
the Generic interface WrDbgArray which has 2 instances each of function for 1 and 2 dimensional integers, 1 and 2 dimensional reals and 1 dimensional Character strings.
