PROTECTED attribute
Svein-Atle_Engeseth
I believe there is an error in the latest Fortran Compiler,
please see the short program below:
      MODULE TEST_PROTECTED_MODULE
      IMPLICIT NONE
      INTEGER :: A = 10
      PRIVATE
      PROTECTED :: A
      SAVE
      END MODULE TEST_PROTECTED_MODULE
      PROGRAM TEST_PROTECTED
      USE, NON_INTRINSIC :: TEST_PROTECTED_MODULE
      IMPLICIT NONE
      INTEGER :: B = 20
      PRINT*, "B = ",B, "  A = ", A
      END PROGRAM TEST_PROTECTED
The compiler complains that A does not have a type and compilation aborts.
If I comment out the PRIVATE statement, the program compiles and works as expected.
My compiler is Intel(R) Compiler 16.0 (package 110)
Svein-Atle Engeseth
andrew_4619
The PRIVATE applies to everything in the module not explicitly given the PUBLIC attribute.
Svein-Atle_Engeseth
So what you are saying is that PROTECTED does not mean PUBLIC and protected from being changed?
That makes the use of PROTECTED very awkward as you have to specify PRIVATE on any entity you want to keep private,
instead of having all PRIVATE and explicitly naming those you want to be PUBLIC or PROTECTED.
Svein-Atle Engeseth
Svein-Atle_Engeseth
Please disregard my previous comment.
I just read in the Fortran 2003 Handbook that the specification is like this:
INTEGER, PUBLIC, PROTECTED :: A
or
INTEGER :: A
PUBLIC :: A
PROTECTED :: A
I apologize for my confusion.
Svein-Atle Engeseth
