PROTECTED within Class
holysword
Hi there,
I am trying to write a simple class but I would like some of its members to be PROTECTED. For instance
TYPE, ABSTRACT :: my_class
INTEGER :: Int1, Int2, Int 3
PROTECTED LOGICAL :: Logical1,Logical2
END TYPEmy_class
The reason is that I don't want the user to try to change the values of Logical1 and Logical2 manually (they are internal flags, let's say), but they should be setted by using the classes's procedures. I have been trying to google anything regarding this, but I was unable to find any answer.
Thanks in advance!!
IanH
The protected attribute is only for module variables, not for components of a derived type.
You can achieve a similar concept to protected (but with different syntax at the point of use) by writing "set and get" procedures for the component.
[fortran]TYPE :: the_type
  PRIVATE
  INTEGER :: the_component
CONTAINS
  PROCEDURE :: Get
  PROCEDURE :: Set
END TYPE the_type
FUNCTION Get(the_object) RESULT(the_value)
  TYPE(the_type), INTENT(IN) :: the_object
  INTEGER :: the_value
  the_value = the_object%the_component
END FUNCTION Get
! If you don't provide this procedure and binding then the value
! would be "read-only" outside its module.
SUBROUTINE Set(the_object, new_value)
  TYPE(the_type), INTENT(INOUT) :: the_object
  INTEGER, INTENT(IN) :: new_value
  the_object%the_component = new_value
  ! ... other stuff that must happen when the_component changes
END SUBROUTINE Set
PROGRAM TypicalUsage
  USE the_module
  TYPE(the_type) :: a
  a%the_component = ...   ! This would be an error.
  CALL a%Set(1)           ! Ok if the Set procedure is provided.
  PRINT "('The value of the component is:',I0)", a%Get()  ! Ok.
[/fortran]
Do you want the user to even read the values? If so, then you want PRIVATE, not PROTECTED. The syntax would be:
PRIVATE ! Change default accessibility of components
INTEGER, PUBLIC :: Int1, Int2, Int3
LOGICAL :: Logical1, Logical2
END TYPE my_class
PROTECTED is for variables that can be read but should not be written to.
IDZ_A_Intel
Note that the PRIVATE statement, if present, has to go before the first component and, if it's present, then all components are private by default. If you just want to make one or two components private, but leave the rest public, then just put the private attribute in the component definitions.
[fortran]ABSTRACT TYPE my_class
  INTEGER :: Int1, Int2, Int3
  LOGICAL, PRIVATE :: Logical1, Logical2
END TYPE my_class[/fortran]
Argh - yes, the standard does indeed require that PRIVATE go before the components. The compiler doesn't catch this, however. Fortran 2003 added the ability to define a private type with public components or vice-versa.
Also, I had an error in the first line - it is "TYPE, ABSTRACT :: my_class" not "ABSTRACT TYPE". I corrected my post with both fixes - apologies for the error.
holysword
Thanks for answering.
Yes, I want the user to read but not to change the value, so its PROTECTED and not PRIVATE.
The version of the compiler in my university doesn't allow me to compile using the same syntax (just changing PRIVATE by PROTECTED). If it is possible at all to set the variable to PROTECTED, which is the oldest version of ifc that allows that?
IanH
  PRIVATE
CONTAINS
  PROCEDURE :: Get
  PROCEDURE :: Set
END TYPE the_type
END FUNCTION Get
END SUBROUTINE Set
  USE the_module
  TYPE(the_type) :: a
[/fortran]
holysword
Yes, I know the idea of get and set methods, but I was trying to avoid it.
Thakn you very much anyway.
holysword
Sorry for ressurrecting the thread, but I have an additional point.
I have the following type
[fortran]TYPE, ABSTRACT :: FATHER_TYPE
  LOGICAL, PRIVATE :: Initialized
CONTAINS
  PROCEDURE :: GetInitialize()
END TYPE FATHER_TYPE[/fortran]
I am using polymorphism and I don't want the routines which use FATHER_TYPE to be able to modify Initialized (I think that the names suggests a lot...).
[fortran]TYPE EXTENDS(FATHER_TYPE) :: CHILD_TYPE
CONTAINS
  PROCEDURE :: Initialize()
I want to be able to set Initialized flag inside Initialize(), but it won't allow me because its a private attribute. If I create a set method inside FATHER_TYPE, then everybody will be able to change it - not much different from having it PUBLIC.
Any idea on how to workaround?
John4
Valued Contributor I
Since nobody has replied to your new post, I guess I'll try to help by pointing out (again) how Fortran ins NOT C/C++:
  1. Fortran accessibility is tied to the module, not to the derived type ---I guess you already noticed that.
  2. Type-bound procedures are overridable by default, unless you use the NON_OVERRIDABLE attribute.
  3. Abstract derived types let you have deferred type-bound procedures ---well, C++ also lets you do that.
  4. Type-bound procedures are, in a certain way, just syntactic sugar (with the notable exception of generic TBP).
Combining 2 and 3, you can apply as many "abstract levels" as you want, and that could solve your problem.
Combining 1 and 4, certainly solves your problem, but only if you're willing/allowed to hide certain implementation details. For example:
[fortran]module mod1
    use iso_fortran_env
    implicit none
    type, abstract :: t1
        logical, private :: read_only = .TRUE.
        logical, private :: flag = .FALSE.
    contains
        procedure :: set
    end type
contains
    subroutine set(this, flag)
        class(t1), intent(INOUT) :: this
        logical, intent(IN) :: flag
    continue
        if (this%read_only) then
            write(ERROR_UNIT, '("this%set is for internal use only")')
        else
            this%flag = flag
        endif
    end subroutine
    subroutine toggle_read_only(this)
    continue
        this%read_only = .NOT. this%read_only
    end subroutine
end module mod1
module mod2
    use mod1
    implicit none
    type, extends(t1) :: t2
    contains
        procedure :: initialize
    end type
contains
    subroutine initialize(this, flag)
        class(t2), intent(INOUT) :: this
    continue
        call toggle_read_only(this)
        call this%set(flag)
    end subroutine
end module mod2
[/fortran]
If toggle_read_only is not documented (or only documented in an advanced section), then any call to the set TBP will trigger an error... And of course, read_only should also be excluded from the documentation intended to the user.
holysword
Hi Jhon, thank you for answering.
Yes, I know all the four points you mentioned, and that's why I asked for a suggestion to workaround.
Well, your idea is a workaround indeed, but the trick is just "don't tell the user abouttoggle_read_only", trusting the user will not mess up with what is not documented, if I understood it correctly. If so, I could let the variable PUBLIC and don't document it.
Another thing that concerns me is that your suggestion would generate an error at runtime, not compile time, which would be the choice of my heart for this situation. I wonder if anything could be done in this sense.
The model Fortran has for accessibility is that everything is visible in the defining module - accessibility controls what USErs of the module can see. Perhaps you could work something with the base type and initializer in one module and then extensions go in a second module.
holysword
I think that you comment has gave me a good idea to workaround...
[fortran]MODULE m_generic
TYPE, ABSTRACT :: T_Father
  INTEGER :: Attrib1
  REAL :: Attrib2
  CONTAINS
   PROCEDURE(IsInitialized_Abstract), DEFERRED :: IsInitialized
   PROCEDURE(Initialize_Abstract),    DEFERRED :: Initialize
END TYPE T_Father
ABSTRACT INTERFACE
   FUNCTION IsInitialized_Abstract(self) RESULT(val)
      IMPORT :: T_Father
      CLASS(T_Father), INTENT(IN)  :: self
      LOGICAL                      :: val
   END FUNCTION IsInitialized_Abstract
   SUBROUTINE Initialize_Abstract(self)
      IMPORT :: T_Father
      CLASS(T_Father), INTENT(INOUT)  :: self
   END SUBROUTINE Initialize_Abstract
END INTERFACE
END MODULE m_generic[/fortran]
[fortran]MODULE m_specific
   USE m_generic
TYPE, EXTENDS(T_Father) :: T_Child
  LOGICAL, PRIVATE :: Initialized = .FALSE.
  CONTAINS
   PROCEDURE, PASS(self) :: IsInitialized
   PROCEDURE, PASS(self) :: Initialize
END TYPE T_Child
 CONTAINS
FUNCTION IsInitialized(self) RESULT(val)
   CLASS(T_Child), INTENT(IN)  :: self
   LOGICAL                     :: val
   val = self%Initialized
SUBROUTINE Initialize(self)
   CLASS(T_Child), INTENT(INOUT)  :: self
   PRINT *,'Im doing initialization'
   self%Initialized = .TRUE.
END MODULE m_specific [/fortran]
[fortran]PROGRAM Main
   USE m_generic
   USE m_specific
CLASS(T_Father), ALLOCATABLE :: father1
TYPE(T_Child)  :: child1
 child1%Attrib1 = 5
 child1%Attrib2 = 3.14
 ALLOCATE(father1, SOURCE=child1)
 PRINT *,'Before Init: ', father1%IsInitialized()
 CALL father1%Initialize()
 PRINT *,'After Init: ', father1%IsInitialized()
END PROGRAM[/fortran]
It will print False first, and then True. The attribute Initialized cannot be accessed via T_Father just because it is not defined there. A drawback is the need to redefine Initialized in every child and as well the get method IsInitialized(). In my case at least, the set method is supposed to be rewriten for every single object, so its not a drawback. An alternative would be to create and intermediate layer with both get and set generic functions and then extend the intermediate layer instead of t_father. I don't like the idea of having these intermediate layers though.
