29656 Discussions
PURE function with EXTERNAL function as argument
mohanmuthu
I am trying to pass a pure function as an argument to another pure function. Is it permissible?
For example,
pure integer function func1(func2, arg2)
    external func2
    integer, intent(in) arg2
    func1 = func2(arg2)
end function func1
pure integer function func1(arg1)
    integer, intent(in) arg1
    func1 = arg1*arg1
end function func1
 I attempted it, but I'm getting an error that the external procedure must be declared pure. If its permissible, how to define the external function as pure.
Arjen_Markus
Rather than specifying func2 as an external, you should specify the exact interface:
interface
    pure integer function func2( arg )
        integer, intent(in) :: arg
    end function func2
end interface
Otherwise the compiler has no way of knowing what the function argument is doing.
Arjen_Markus
interface
    end function func2
end interface
mohanmuthu
Thank you Arjen_Markus, I could make it work with your solution.
