29655 Discussions
Packing an allocatable derived type array gets messed up after deallocating the original array
kostas85
Hello All,
When an allocatable derived type array (say container) is packed (using the intrinsic pack function) then the content of the resulting array (say packed_container) change when deallocating the original array. To clarify, in the following program the array packed_container is printed before and after deallocating container. Please let me know if you can reproduce the result. Up to now I don't have any suggestion for a workaround I would  appreciate any help on this. Many thanks in advance.
Kostas
PS: The code and it'output follow, compiled by ifort 14.0.2.144
module my_storage_type
implicit none
type storage1
  integer :: id=0
  integer, dimension(:), allocatable :: lowkey
end type storage1
end module my_storage_type
program compress_test
use my_storage_type
implicit none
type(storage1), dimension(:), allocatable :: container, cont_he
integer :: i
! inits
 allocate(container(4))
 container(1)%id = 2
 allocate(container(1)%lowkey,source=(/1,2,3,4/))
 container(3)%id = 5
 allocate(container(3)%lowkey,source=(/5,6,7,8/))
allocate(cont_he,source=pack(container,container%id/=0))
print *, " output before deallocating container"
print *, cont_he
deallocate(container)
print *, " output after deallocating container"
print *, cont_he
end program compress_test
produces the output:
           2           1           2           3           4           5
           5           6           7           8
           2           0           0           3           4           5
    11551136           0           7           8
kostas85
A Note
When I referred to a workaround I implied using the pack intrinsic. For example note that replacing the allocate(...,source=pack(...)) line of the code above with a "user" pack procedure such as:
allocate(cont_he(count(container%id/=0)))
cnt = 0
do i=1,size(container)
    if (container(i)%id/=0) then
    cnt = cnt + 1
    cont_he(cnt) = container(i)
    end if
end do
produces the correct result. I'm sorry, I forgot to mention this :)
John4
Valued Contributor I
Since the problem seems to be with the PACK intrinsic, I think your only workaround is not to use said intrinsic.  The code causes an ICE in gfortran 4.8, and gfortran 4.9+ doesn't seem to support SOURCE= in the allocate statement. sunf90 complains about the allocatable components in the PRINT statements, but after changing those to
print *, (cont_he(i)%id, cont_he(i)%lowkey, i = 1, SIZE(cont_he))
the code compiles just fine and produces the expected results:
...:~$ ll `which sunf90`
lrwxrwxrwx 1 root root 5 Mar 17 20:58 /opt/solarisstudio12.4/bin/sunf90 -> ./f90*
...:~$ sunf90 test_pack.f90
...:~$ ./a.out
 2 1 2 3 4 5 5 6 7 8
 2 1 2 3 4 5 5 6 7 8
...:~$ ll `which ifort`
-rwxr-xr-x 1 root root 4013312 Apr 25 08:19 /opt/intel/composer_xe_2013_sp1.3.174/bin/intel64/ifort*
...:~$ ifort test_pack.f90
...:~$ ./a.out
           2           1           2           3           4           5
           5           6           7           8
           2           0           0           3           4           5
    32641440           0           7           8
kostas85
Thanks a lot John for your feedback! For now, I've coded the packing without the pack intrinsic. It's really interesting that both gfortran and ifort give the same error.
Xiaoping_D_Intel
It is a known issue in "PACK" and has been fixed in 15.0 beta compiler.
Xiaoping Duan
Intel Customer Support
