Parallel Studio intgretion with VS
Eldhuset__Knut
Hello
I  installed Windows 10 recently. I want to run Fortran 64 with both command line and debugger. I first installed Visual Studio Professional 2017.
Then I run parallel_studio_xe_2019_update5_professional_edition_setup. However, they don't integrate.
The versions that worked on Windows 7 was Parallel Studio 2017 and Visual Studio 2013, not newer versions than that.
Which versions do you recommend in Windows 10 ?
Kind regards Knut Eldhuset
Norwegian Defence Research Establishment(FFI)
Steve_Lionel
That combination should work. Be sure to follow the instructions in https://software.intel.com/en-us/articles/intel-c-fortran-compilers-for-windows-integration-into-microsoft-visual-studio-2017
