29434 Discussions
Parameters not passed correctly - why??
jim_cox
I have a problem with passed parameters
On arriving at a called routine I find that values are nothing like what was originally set
The code looks like this....
CHARACTER*1 SCRAMBLED*20, KEY_SITEFILE*20
INTEGER(4) OUT_DATE(3)
LOGICAL*4 ERR
SCRAMBLED = 'ONJIAOLZ537 '
KEY_SITEFILE = 'GabitesPorter '
OUTDATE = 0
ERR = .FALSE.
CALL DECODEDATE(SCRAMBLED, KEY_SITEFILE, OUT_DATE, ERR)
But when we get there...
SUBROUTINE DECODEDATE(IN_KEY, IN_CRYPT, OUT_DATE, ERR)
CHARACTER*1 IN_KEY*20, IN_CRYPT*20
LOGICAL*4 ERR
We find that...
IN_KEY = 'O '
IN_CRYPT = ' '
OUT_DATE(1) = Undefined address
OUT_DATE(2) = Undefined address
OUT_DATE(3) = Undefined address
ERR = .TRUE.
Both pieces of code reside in the same file
Any ideas what might cause this?
Thankx for your help
Jim
Desperate in Christchurch
The code "looks like" that or "is" that? If I work up a complete example based on what you showed, I get different behavior. I will note that you declare OUT_DATE but assign to OUTDATE.
Which compiler and version are you using?
jim_cox
I have since found that setting iface/:CVF sorted the problem
Thankx
onkelhotte
New Contributor II
Quoting - jim.cox
Why do you use character*1 and then scrambled*20?
When you look at the first parameter of your routine, it also has only one character. Doesnt look like clean coding, using some compiler options to get rid of itis not the way to go...
Markus
That use of *1 and *20 is legal, but confusing.
If /iface:CVF sorted the problem, then what you showed us was not representative of the actual code or organization.
jim_cox
Quoting - onkelhotte
Markus
Agreed
It is nasty 20 year old code
And moving to the Intel compiler is uncovering a whole heap of "issues"
At least I now have a build that runs (sort of) and is debug-able
