29390 Discussions
Passing a two-dimensional dynamic array from CPP to FORTRAN
Malik_M_
Can't run a mixed language program with dynamical array.
CPP call FORTRAN  as listed below.
CPP main program calls a fortran sub with the dynamic 2d array passing.
Compiling and linking phase was successful. However,
the following message is displayed, after execution
"segmentation fault: 11"
WHAT'S HAPPENED?
Thank you very much for help.
Malik.
#include <iostream>
#include <stdlib.h>
#include <assert.h>
using namespace std;
const int MAXSIZE = 10;
extern "C"
    void fsub(int**, int, int);
int main()
      int *A[MAXSIZE],  size;
      int  i, j, ir, jc;
      cout<<"\nRow size:";
      cin>>ir;
      cout<<"\nCol size:";
      cin>>jc;
      for( i=0;i<ir;++i)
          A = new int[jc];
          assert(A != 0);
      for(i=0; i<ir; ++i)
         for(j=0; j<jc; ++j)
              A = 3;
          cout<<"\nA["<<i<<"]"<<"["<<j<<"]= "<<A;
          cout<<endl<<"FORTRAN calling"<<endl;
          fsub(A,ir,jc);
          for(i=0; i<ir; i++)
                for(j=0; j<jc; j++)
                cout<<"A["<<i<<"]["<<j<<"]="<<A<<endl;
        delete[] *A;
  return EXIT_SUCCESS;
FORTRAN SIDE,
 SUBROUTINE FSUB(A, ROWS, COLS)BIND(C,name="fsub")
 USE, INTRINSIC :: ISO_C_BINDING
 IMPLICIT NONE
 INTEGER(KIND=C_INT), INTENT(IN), VALUE :: ROWS, COLS
 INTEGER(KIND=C_INT), INTENT(INOUT)       :: A(10,COLS)
 INTEGER                                                           :: I, J
 A=TRANSPOSE(A)
 DO I =1, ROWS
     DO J = 1, COLS
         A(I,J) = A(I,J)*100;
     ENDDO
 ENDDO
 END
TimP
Fortran multidimensional arrays aren't implemented with multiple layers of pointers. They are equivalent to plain c "arrays" where indexing involves calculating the offsets f2c style (almost trivial to accomplish with macro).
jimdempseyatthecove
On the C/C++ side, allocate the total amount of data in one allocation:
int* blob = new int[ir*jc];
assert(blob!=0);
for(int i=0;i<ir;++i)
   A = &blob[i*jc];
The A array of int* is available to C++, the call to Fortran would pass the base (blob) and the two dimensions ir and jc. Fortran would then construct the appropriate array descriptor from the dummy arguments.
Jim Dempsey
Malik_M_
Thank you both, Tim and Jim!
I'm understand that interchanging arrays with the CPP and FORTRAN can be allowed via a 'flat' arrays only. :(
Malik.
PS. I has programmed in Symantec C++(Zortec C++) many years ago. Symantec C++ was supported by NCEG (Numerical C Extension Group)
There was an extern "FORTRAN" name conversions, instead the extern "C" above.
