29648 Discussions
Passing function/subroutine addresses
dbruceg
I suspect this will ultimately be revealed as a stupid question, but I can't seem to figure it out. Consider the following:
external ErrorExit
integer(4) hErrorExit
hErrorExit = %loc(ErrorExit)! address of routine ErrorExit
call ErrorExitLocal (%val(hErrorExit))! tell ErrorExitLocal who to call
subroutine ErrorExitLocal (ErrorExitSub)
external ErrorExitSub
call ErrorExitSub! actually calls ErrorExit
The idea here is to be able to pass the address of a main-programerror routine into a DLL, such that different programs using the same DLL can handle errors in their own ways.
VF9.1 doesn't like this construct if it checks routine interfaces, suggesting that I need an interface block, but I can't figure out what that interface block should look like. Anybody have a hint?
Bruce
You're making it more complicated than is necessary. This will work:
call ErrorExitLocal(ErrorExit)
dbruceg
Your suggestion requires thatthe reference to ErrorExit be resolved at the time of DLL linkage. That's what I'm trying to avoid. I want to tell the DLL who to call at run time.
dbruceg
This is just a test. It looks like a "Quick reply" does not change the name in "Last Post by"
Sorry, I had understood that the first call was from the main program. Ok, you want to select at run-time the routine to call. You can do it this way: Leave the caller the way you have it except remove the %VAL. Make the called routine look like this:
subroutine ErrorExitLocal (PErrorExitSub)
pointer (PErrorExitSub, ErrorExitSub)
dbruceg
That's too clean!
Plus, it works. Thank you very much
Bruce
I suggest the following change in the caller: Change:
to:
integer(int_ptr_kind()) hErrorExit
This way it will still work under 64-bits.
dbruceg
Thanks. Iwish that was the only problem I'll have to face when I raise this thing to 64 bits. - Bruce
