Passing start parameters?
h-faber
is it possible to catch start parameters which I want to submit on the command line? I want to call something like
myfortranprog.exe param1 param2
Is this possible, if so, how can I access these parameters in the Fortran code?
Thanks in advance.
anthonyrichards
New Contributor III
Look at the DFLIB routine GETARG for getting command-line arguments, along with NARGS for counting them. You need to add USE DFLIB to your code.
h-faber
thanks a lot, works perfectly!
How do you know of this lib and these functions? Is there any documentation available for this and the other libraries such as dfcom, dfauto etc.?
All the library routines are documented in the on-disk documentation.
anthonyrichards
New Contributor III
Hi. I should of course have mentioned that I use Compaq Visual Fortran (CVF) 6.6, not Intel Fortran, hence the mention of DFLIB.The routines are in appendix E in the printedFORTRAN Reference manual that came with it. I admit, the on-line documentation is lacking as to how to find them without knowing they are there.
I think you will find that the routine is listed in the on-disk documentation index, and is included in the documentation of the portability routines.
Note that in Intel Fortran, GETARG is an intrinsic routine.
