29530 Discussions
Passing type bounded procedure to Quadpack
pDs
Greetings,
I'd like to pass a type bounded procedure to Quadpack's qagpi integrator. Is there a way I could do that? The following code generates a SIGSEGV... so I'm doing this very wrong.
Any help would be much appreciated.
Thanks!
module A
      use B
      use C
      implicit none
      type L
      real                           :: vs
      integer                        :: itermax
      contains
      procedure                      :: a1=>A1
      procedure                      :: b1=>B1
      procedure                      :: c1=>C1
      procedure                      :: d1=>D1
      procedure                      :: e1=>E1
      procedure                      :: intgrd=>integrand
      end type L
      real function D1 ( this, r)
      class(L)   , intent(in) :: this
      real (kind = 4)  ,intent(inout) :: r
! Do something
      D1 = somevalue
      return
      end function D1
      real function E1 ( this, r)
! Do something
      E1 = somevalue
      return
      end function E1
      real function integrand(this, r)
      real                            :: x, y
      x = this% D1(r)
      y= this% E1(r)
      integrand = x * (y**2) / r
      return
      end function integrand
      real function A1(this, r)
      real (kind = 4)     , intent(in) :: r
      real (kind = 4)                  :: a
      real ( kind = 4 )                :: abserr
      real ( kind = 4 )    , parameter :: epsabs = 0.0E+00
      real ( kind = 4 )    , parameter :: epsrel = 1E-06
      integer ( kind = 4 )             :: ier
      integer ( kind = 4 ) , parameter :: inf = 1
      integer ( kind = 4 )             :: neval
      real ( kind = 4 )    , parameter :: r4_pi = 3.141592653589793E+00
      real ( kind = 4 )                :: result
      a = real ( r, 4 )
      call qagi ( this% intgrd,
     &            a, inf, epsabs, epsrel,
     &            result,
     &            abserr,
     &            neval,
     &            ier)
      A1 = - result
      return
      end function A1
end module A
mecej4
Please provide valid source code. The lines you gave above do not form a complete program acceptable to the compiler.
Was it the compiler, or the compiled and linked program generated from your source code, that produced the seg-fault?
Which version of Quadpack do you use, and what is the interface of its QAGI? Are you using the Fortran 77 implicit interface?
