Passing values from C++ to Fortran
cfann61
I've been working on the stdcall example I found on the web at: http://www.neurophys.wisc.edu/comp/docs/notes/not017.htmland I was able to get the C++ to call the Fortran subroutine, but the values from C++ aren't passing to Fortran and vice versa. I've made the code a bit simpler and here's what I've got.
// This illustrates how a Fortran routine and function may be
// called from a main program in C++
#include
float n=10;
float nSq;
extern "C" void __stdcall FR1(float *,float * nSq);
void main()
FR1(&n,&nSq);
and:
SUBROUTINE
FR1(N,M)
!DEC$ ATTRIBUTES STDCALL, ALIAS:'_FR1@8'::FR1
! COMPUTES THE SQUARE OF N, RETURNS IN M
REAL
M,N
M=N*N
RETURN
END
The value of N when I get into the Fortran subroutine is a random number(i.e. 6.06...E-39). The values of N and M when I get back into the C++ are 10 and 0, respectively. Any help would be appreciated.
Lorri_M_Intel
The "STDCALL" attribute changes the default passing mechanism for numeric argument from "by reference" to "by value". Your C program is passing by reference, so the Fortran program is interpreting the address of these values as the actual values.
Fix is easy; change the attributes to:
!DEC$ ATTRIBUTES STDCALL, REFERENCE, ALIAS:'_FR1@8'::FR1
and it should work for you.
- Lorri
Or my preference:
!DEC$ ATTRIBUTES STDCALL,REFERENCE,DECORATE,ALIAS:"FR1" :: FR1
cfann61
Or my preference:
Is there any advantage of one over the other, or is it just a preference?
cfann61
Changed Fortran to:
SUBROUTINE
FR1(N,M)
!DEC$ ATTRIBUTES STDCALL,REFERENCE,DECORATE,ALIAS:'FR1'::FR1
REAL
M,N
M=N*N
RETURN
END
Still not passing value of N.
It worked fine for me when I tried it.
joerg_kuthe
Since you pass pointers and because you also declared FR1 to be STDCALL conform, don't you have to specify explicitely that you pass N and M by reference?
SUBROUTINE FR1(N,M)
!DEC$ ATTRIBUTES REFERENCE :: N,M
REAL M,N
Hope that helps.
Jrg Kuthe
www.qtsoftware.de
Jugoslav_Dujic
Valued Contributor II
Quoting - joerg_kuthe
No, the REFERENCE attribute for the FR1 means that all the arguments are passed by reference by default (unless explicitly overriden).
