29386 Discussions
Performance of `ifx -fast` when invariant if conditions in loops.
pedro
I am trying to understand the consequences of replacing CPP macros with loop-invariant `if` conditions. Typically, with optimization on, I see no performance difference in most compilers I have checked, including `ifx` with less aggressive optimization. The exception is `ifx` with the `-fast` option.
Consider the following codes:
program test_cpp
  implicit none
  integer, parameter :: nx = 500, ny = 500, nz = 500
  integer :: i, j, k
  real :: field(nx, ny, nz)
  real :: diff1, diff2, res
  integer :: iunit
  real(8) :: t2,t1
  ! initialize data
  do k = 1, nz
    do j = 1, ny
      do i = 1, nx
        field(i, j, k) = i + j*10. + k*100.
      end do
    end do
  end do
  ! run kernel
  call cpu_time(t1)
  do k = 1, nz
    do j = 1, ny
      do i = 1, nx
        diff1 = field(i, j, k) + 1.
        diff2 = field(i, j, k) - 1.
#if defined(_OPTION_1)
#if defined(_OPTION_1_PLUS)
        res = diff1 + diff2
#else
        res = diff1 * diff2
#endif
#else
        res = diff1 - diff2
#endif
        field(i, j, k) = res
      end do
    end do
  end do
  call cpu_time(t2)
  print*,'Elapsed time: ', t2-t1
  ! save data
  open(newunit=iunit, file="output.bin", form="unformatted", access="stream", status="replace")
  write(iunit) field
  close(iunit)
  print*, 'field(3,3,3) = ', field(3,3,3)
end program test_cpp
and:
program test_nocpp
  implicit none
  integer :: i, j, k
  integer :: iunit
  integer :: option1, option1_plus
  character(len=32) :: arg
  real(8) :: t2,t1
  ! get options from the command line
  if (command_argument_count() >= 1) then
    call get_command_argument(1, arg)
    read(arg, *) option1
  else
    option1 = 0
  endif
  if (command_argument_count() >= 2) then
    call get_command_argument(2, arg)
    read(arg, *) option1_plus
  else
    option1_plus = 0
  endif
  ! initialize data
  do k = 1, nz
    do j = 1, ny
      do i = 1, nx
      end do
    end do
  end do
  ! run kernel
  call cpu_time(t1)
  do k = 1, nz
    do j = 1, ny
      do i = 1, nx
        if (option1 == 1) then
          if (option1_plus == 1) then
            res = diff1 + diff2
          else
            res = diff1 * diff2
          endif
        else
          res = diff1 - diff2
        endif
      end do
    end do
  end do
  call cpu_time(t2)
  ! save data
  write(iunit) field
  close(iunit)
end program test_nocpp
I do not get a performance difference when compiling with `-O2` and `-O3`, but I do it with `-fast:
$ ifx -fast test_nocpp.f90 -o test_nocpp && ./test_nocpp 1 1 && ifx -fast -cpp -D_OPTION_1 -D_OPTION_1_PLUS test_cpp.f90 -o test_cpp && ./test_cpp
ld: /home/x/software/intel/oneapi/compiler/2025.0/lib/libifcoremt.a(for_close_proc.o): in function `for__close_proc':
for_close_proc.c:(.text+0x1c1): warning: Using 'dlopen' in statically linked applications requires at runtime the shared libraries from the glibc version used for linking
Elapsed time: 5.109700000000000E-002
field(3,3,3) = 666.0000
Elapsed time: 4.904699999999998E-002
ifx -O3 test_nocpp.f90 -o test_nocpp && ./test_nocpp 1 1 && ifx -O3 -cpp -D_OPTION_1 -D_OPTION_1_PLUS test_cpp.f90 -o test_cpp && ./test_cpp
Elapsed time: 4.818600000000001E-002
Elapsed time: 4.819499999999999E-002
Why isn't `-fast` able to optimize the code with loop-invariant if conditions as efficiently as the code with CPP macros? Is there a flag I can pass to recover the performance of `test_cpp.f90`
Thanks!
pedro
To add to this, I found in the compiler reference that `-fast` is equivalent to `-ipo, -O3, -static, -fp-model fast`.
However, compiling with `-ipo, -O3, -static, -fp-model fast`, I get the same performance for both implementations:
ifx -ipo -O3 -static -fp-model fast test_nocpp.f90 -o test_nocpp && ./test_nocpp 1 1 && ifx -ipo -O3 -static -fp-model fast -cpp -D_OPTION_1 -D_OPTION_1_PLUS test_cpp.f90 -o test_cpp && ./test_cpp
 Elapsed time:   4.875399999999999E-002
 Elapsed time:   4.877200000000001E-002
 I thought `-fast` was short for `-ipo, -O3, -static, -fp-model fast`, but I see quite a difference in performance between the two.
I am using ifx 2025.0.4 20241205.
It would be nice to get some clarity on this. Thanks in advance!
Ron_Green
Several comments here that may help.
First, you don't need to use cpp.  You can use fpp.  If you name the file  with extension .F90 you get fpp invoked by default.  fpp parses the  #if defines just like cpp.  you can confirm by using the -keep option and checking the output .i90 file for the preprocessed source.
example
ifx -O2 -D_OPTION_1 -D_OPTION_1_PLUS test_fpp.F90 -keep
more test_fpp.i90
! run kernel
  call cpu_time(t1)
  do k = 1, nz
    do j = 1, ny
      do i = 1, nx
        res = diff1 + diff2
# 33
# 36
      end do
    end do
  end do
  call cpu_time(t2)
Now, onto the performance questions
1) You can use -qopt-report 3 to generate optimization reports to compare versions, options, etc.  compile with
-qopt-report-3
option.  Then look for the <file>.optrpt.  compare the opt reports for different options and defines.
2) you can dump assembly language and remove any doubt about generated code
ifx -O2 -D_OPTION_1 -D_OPTION_1_PLUS test_fpp.F90 -S
look for test_fpp.s for the assembly version of your code
3) You can look at all defines and options the compiler uses with option
or
-dryrun
4) options and what not:  ifx uses default LLVM optimizations for O1 - O2.  To trigger additional optimizations you can add
-xhost
if you have a genuine Intel Processor.  This kicks in additional optimizations.  -ipo will help with that also, as will -flto
I think this will give you the tools you need for your analysis.
pedro
Thanks!
I wonder if you have any idea why `-fast` performs poorer than `-ipo, -O3, -static, -fp-model fast`. From the docs, I read that they're equivalent...
Pedro
Steve_Lionel
It's not documented, but -fast also implies -xHost. Perhaps the advanced instructions are not optimal for your application. (This really should be documented!)
pedro
Ha... Indeed, I think this was also `ifort`'s behavior, so it makes sense. Thank you, Steve!
