29653 Discussions
Pointer problem in mixed language programming
jaeger0
I have Problems using a linked-list structure PAT_lst, which I use in Fortran and C.
I have the following structures in Fortran
type, BIND(C):: PAT_inf
character(TYP_PN) name ! PN patient name
character(TYP_LO) id ! LO patient iD
character(TYP_DA) birth ! DA patient birth
character(TYP_CS) sex ! CS patient sex
character(TYP_AS) age ! AS patient age
integer(TYP_IS) nStd ! IS NumberOfPatientRelatedStudies
integer(TYP_IS) nSer ! IS NumberOfPatientRelatedSeries
integer(TYP_IS) nIns ! IS NumberOfPatientRelatedInstances
end type
type:: PAT_it
type(PAT_inf) item
type(PAT_it), pointer:: next
type(PAT_it), pointer:: prev
end type
type:: PAT_lst
type(PAT_it),pointer:: list_top
type(PAT_it),pointer:: list_bot
integer(TYP_IS) nPat
end type
with the global variable type(PAT_lst) PatList;
I call the C-subroutine with
SUBROUTINE call_findscu (p_res,pacs_opt, PatList, debug,verbose)
use PACS_DEF
! Specify C calling and naming conventions
!DEC$ ATTRIBUTES C :: call_findscu
INTEGER, INTENT(IN) :: debug,verbose
type(PACS_RES) p_res
type(PACS_CONF) pacs_opt
! Specify that the CHARACTER arguments are by reference
! with no hidden length
!DEC$ ATTRIBUTES REFERENCE :: p_res,pacs_opt, PatList
END SUBROUTINE call_findscu
the C-structures are:
PAT_lst PatList; // the dynamic patient list
struct PAT_lst{
struct PAT_it *list_top; // top of patient list
struct PAT_it *list_bot; // bottom of patient list (last item inserted)
int nPat; // number of patients in list
with the C- function
extern "C" void call_findscu(PACS_RES *p_res, PACS_CONF *pacs_opt, PAT_lst *iPatList, int debug, int verbose) {
FILE *o_file;
filebuf out_file;
filebuf err_file;
PatList = *iPatList;
PAT_lst_Init(PatList); // initialize patient list
here I add items to the dynamic list, and all works.
However back in the Fortran subroutine PatList, is vieable, with the debugger ( all items), but I cannot acess the values, for example
item => PatList%list_top, results with undefined pointer for item, even for the debugger PatList%list_top is viewable
Is there any problems using this datatypes ? For the structure PAT_lst I can not use the BIND(C), option, like for type, BIND(C):: PAT_inf
Any guess what the Problem could be ?
TimP
I would have thought C_F_POINTER would be required to make a Fortran copy of the pointer.
jaeger0
Hmm, now it works.
The problem was in the C-source, where I had to replace the definition of
PAT_lst PatList; by PAT_lst *PatList;
but Have I to use
CALL C_F_POINTER(PatList%list_top, item)
instead of
for me works, at the moment the second expression. Is this correct ?
Jugoslav_Dujic
Valued Contributor II
The bottom line: you can, but you don't have a guarantee for it. Intel's implementation of the scalar POINTERs happens to be interoperable with C pointers, but it may change in the future, or if you change the compiler.
I've also been bitten using Fortran POINTERs as arguments or results of BIND(C) functions in 11.1. When 12.0 came, I had to say goodbye. The difference with your case is that the Standard explicitly forbid it (but 11.1 didn't bother to check), while you're outside of the standard's scope (no Bind(C), no checking).
So, if you're in pedantry mood, change the code. In my case, it wasn't cheap at all, so I was forced to switch back to !DEC$ATTRIBUTES for interoperability.
JVanB
ifort doesn't catch this?
jaeger0
no problem with this
