29657 Discussions
Pointer to array section and vector subscripts
Gustavo_Colvero
Hi, I'm trying to make a pointer point to an array subsection resolved by a vector subscript, but I found it
not to be possible.
Given
[fortran]DOUBLE PRECISION, DIMENSION(5,5), TARGET :: arrA
DOUBLE PRECISION, DIMENSION(:,:), POINTER :: ptr1
[/fortran]
the assignment
[fortran]ptr1 => arrA(1:3,(/2,4/)) [/fortran]
was intended to make pointer ptr1 point to the subsection of arrA constituted of its columns 2 and 4 for
rows 1 to 3, but I get the error
[fortran]#6797: A vector subscript is not permitted in an array section target subobject[/fortran]
Is it possible to do something like this?
PS: I'm not using a triplet on the second index because, in practice, I'll select more columns without a
regular stride.
No - the standard explicitly forbids data-target from being an array section with a vector subscript. (Constraint C724 in Fortran 2008).
Gustavo_Colvero
Ok. I'll work some bypass.
