Pointer
christian_rackl
Is it possible to set a pointer to a member-variable of a structure?
how?
keefer
Yes, It is possible. The elements of the structure need to be defined as a derived type. A pointer is then declared as that type. If your structure is an array of these derived types, the simply assign the (already declared Pointer) to the element you want. You probably need to define a target,. such as the array.
Keith
P.S. I am often wrong, but my reply should generate messages correcting me.
