Poisson Solver in Fortran
Jason_W_2
I am trying to use the Poisson Solver with the  sample "d_Laplace_2D.f90". I include the MKL_DFTI.90, which is referenced. The error I received was as follows:
Severity    Code    Description    Project    File    Line    Suppression State
Error        error #7002: Error in opening the compiled module file.  Check INCLUDE paths.   [MKL_DFT_TYPE]        C:\PROGRA~2\INTELS~1\COMPIL~1.207\windows\mkl\include\MKL_DFTI.F90    228
 MKL_DFT_TYPE is a module inside the file MLK_DFTI.90 , so why would I receive an error and have to check INCLUDE paths..
Jason
Arjen_Markus
What do you mean by "I include the MKL_DFTI.90"? I looked at the source code of these examples and it is simply referred to as a module - the comment in d_laplace_2d.f90 is misleading. Fortran has an INCLUDE statement, but that does something completely different than the USE statement.
What you need to do is:
  • Compile the various source files, mkl_dfti.f90, mkl_poisson.f90 etc first
  • Compile d_laplace_2d.f90 and link the program together with its dependendies
There are several ways to do that:
  • Via the sample makefile in the examples collection
  • By setting up a solution/project that contains all of these files
The first is the fastest way forward, the second the most instructive.
Arjen
