29655 Discussions
Polymorphic Variable Detecting Arrays
Vasili_M_
Is it possible for an unlimited polymorphic variable to detecd an array.
subroutine test (tn)
  class (*), Intent (Out) :: tn
  Select type (tn)
  Type Is (Integer, dimension(:))
    tn = 3
  End Select
end subroutine
Fortran 2015 (and TS29113 "Further Interoperability with C") extends the language to include "assumed rank". You can query the rank of an assumed-rank dummy argument, but you're somewhat limited in what you can do with it. However, your code could be implemented this way (in a compiler with this support, which ifort doesn't yet have):
  use, intrinsic :: iso_c_binding
  class (*), dimension(..), Intent (Out) :: tn
  integer, pointer, dimension(:) :: tn_i_1
  integer, pointer, dimension(:,:) :: tn_i_2
  Select type (tn)
  Type Is (Integer)
   select case (rank(tn))
   case(1)
   call c_f_pointer (c_loc(tn),tn_i_1,shape(tn))
    tn_i_1 = 3
   case(2)
    call c_f_pointer(c_loc(tn),tn_i_2,shape(tn))
    tn_i_2 = 4
    end select
  End Select
end subroutine
Still not as nice as you'd like, but at least doable.
IanH
Not in that manner.
An unlimited polymorphic object can be an array, but you cannot change its "arrayness" with SELECT TYPE.
SUBROUTINE sub(arg)
  CLASS(*), INTENT(IN) :: arg(:,:)    !<-- Rank two array here.
  SELECT TYPE (arg)
  TYPE IS (INTEGER)
     PRINT *, arg(1,2)    !<-- Still a rank two array.
You can make the array a component of a derived type and then select on that type.
TYPE :: Rank2Type
  INTEGER, ALLOCATABLE :: array(:,:)
END TYPE Rank2Type
TYPE :: Rank3Type
  INTEGER, ALLOCATABLE :: array(:,:,:)
END TYPE Rank3Type
SUBROUTINE sub(arg)
  CLASS(*), INTENT(IN) :: arg   !<-- A scalar.
  SELECT TYPE (arg)
  TYPE IS (Rank2Type)
    PRINT *, arg%array(1,2)    !<-- Component is a rank two array.
  TYPE IS (Rank3Type)
    PRINT *, arg%array(1,2,3)  !<-- Component is a rank three array.
  Select type (tn)
  Type Is (Integer)
   case(1)
    tn_i_1 = 3
   case(2)
    tn_i_2 = 4
    end select
  End Select
end subroutine
