Portable function link error
xinjian_qian
I used intel visual fortran 9 for windows port CVF 6 project in VC.net 2003. I got the following link error.
libhsprsg.lib(cntl.obj) : error LNK2019: unresolved external symbol _BEEPQQ@8 referenced in function _CNTL_CLEANUP
libhsprsg.lib(envget.obj) : error LNK2019: unresolved external symbol _GETENVQQ@16 referenced in function _ENVGET
libhsprsg.lib(readlibs.obj) : error LNK2019: unresolved external symbol _GETENV@16 referenced in function _READLIBS
libhsprsg.lib(iob_readin.obj) : error LNK2019: unresolved external symbol _GETENV@16 referenced in function _IOB_READIN
my project setting is:
call conversion: CVF
use portable library: yes.
If we set "call conversion" to "Default", The link error are ok. but I wish to using "CVF" (because it will have much errors when using "Default"). How do I do to clean such link error?
Best Regards!
Lorri_M_Intel
Make sure you have
USE IFPORT
(or USE DFPORT)
in your source file.
That MOD file will make sure the correct external names are generated for these portability functions.
- Lorri
xinjian_qian
Thanks Lorri, I will try it. Our project is porting from VC6.0 + CVF6 to VC.net 2003 + IVF9. I remembered we used the "USE DFPORT" in CVF6, when porting to IVF9, I removed it, so get the link error. I will try it. Thanks!
Best Regards!
xinjian_qian
Thanks Lorri!
David
