29657 Discussions
Position-dependent explicit interface?
John4
Valued Contributor I
When I try to compile the code below, I get an error stating that the specified interface (for the procedure func) is not declared. But if I place the "square" function right before "loopOverFunc" then I get no error (although I get a misleading warning regarding the result of the "square" function). Is it a bug in the compiler or the intended behavior?
module mod1
implicit none
contains
function loopOverFunc(func, array) result(sq)
procedure(square) :: func
integer, intent(IN) :: array(:)
integer :: sq(SIZE(array))
integer :: i
continue
do i = 1, SIZE(array)
sq(i) = func(array(i))
enddo
end function
elemental function square(a) result(sq)
integer :: sq
continue
sq = a ** 2
end function
end module mod1
These issues have been fixed in our sources. The fix should appear in 11.1 Update 5, scheduled for mid-February.
Looks like a bug or two - we'll investigate.
Both issues have been escalated as DPD200141623.
Fixed in 11.1 Update 6, available now.
