29654 Discussions
Possible IFX 2025.2.0 optimization bug (-O2 vs -O1)
cfried
I believe I have found a compiler bug in IFX 2025.2.0. The problem occurs with -O2 but not with -O1.
The following reproducer stops with
STOP "slice element 1 incorrect"
when compiled with -O2, but runs correctly with -O1.
program test
   use iso_fortran_env, only : real64
   implicit none
   integer, parameter :: n = 49
   complex(real64), allocatable :: a(:,:,:,:) ! Works for an automatic array
   complex(real64) :: tmp(2)
   integer :: i,j,k
   allocate(a(-n:n,-n:n,-n:n,2))
   a = (0.0_real64,0.0_real64)
   a(0,0,0,1) = (1.0_real64,0.0_real64)
   a(0,0,0,2) = (2.0_real64,0.0_real64)
   tmp = a(0,0,0,:)
   print *, "scalar 1 =", a(0,0,0,1)
   print *, "scalar 2 =", a(0,0,0,2)
   print *, "slice    =", tmp
   if (tmp(1) /= a(0,0,0,1)) stop "slice element 1 incorrect"
   if (tmp(2) /= a(0,0,0,2)) stop "slice element 2 incorrect"
   deallocate(a)
end program
Observations:
  • The problem is reproducible with an allocatable array.
  • The problem disappears when using an automatic (stack) array instead.
  • The array has non-unit lower bounds.
  • The problem occurs only with -O2; -O1 behaves correctly.
In addition, I encountered two possibly related issues in a larger application:
  1. Array section passed as actual argument
A call of the form
call potential_coul(..., dpw(:,:,:,:nspin), ...)
caused a segmentation fault when running under Valgrind.
Replacing it by
call potential_coul(..., dpw, ...)
eliminated the crash.
In this case the two forms are semantically equivalent because the full array extent is passed.
  1. Automatic character length
The declaration
character(len_trim(string)) :: str
triggered a Valgrind warning:
Conditional jump or move depends on uninitialised value(s)
inside the Intel runtime library.
Changing the declaration to
character(len(string)) :: str
eliminated the warning.
I do not know whether these three observations are related, but they all involve compiler-generated descriptors/temporaries and all occurred with IFX 2025.2.0.
Has anyone seen similar issues, or can this be reproduced by Intel?
Shiquan_Su
We tested your reproducer against our latest oneapi 2026.0 release. The issue goes away. Please upgrade your oneapi version to 2026.0 to fix the issue.
$ cat runme.sh
#!/bin/bash
module purge
module load intel/oneapi/2026.0
ifx -O2 test.f90
./a.out
$ cat test.f90
program test
  implicit none
  integer :: i,j,k
  tmp = a(0,0,0,:)
  deallocate(a)
end program
$ . ./runme.sh
 scalar 1 = (1.00000000000000,0.000000000000000E+000)
 scalar 2 = (2.00000000000000,0.000000000000000E+000)
 slice  = (1.00000000000000,0.000000000000000E+000)
Shiquan_Su
$ cat runme.sh
#!/bin/bash
module purge
ifx -O2 test.f90
./a.out
$ cat test.f90
program test
  implicit none
  integer :: i,j,k
  tmp = a(0,0,0,:)
  deallocate(a)
end program
$ . ./runme.sh
