Possible ifc bug
vidar987
I'm trying to compile HOMPACK90 (from Netlib) with ifc 7.1 and am getting the following error message:
USE HOMOTOPY, QR => QRSPARSE
Error 208 at (886:HOMPACK90.f) : No such entity in the module
The code compiles and passes tests with Lahey 6.2 and Sun Forte 7 compilers. I've spent a lot of time checking the code and it seems fine. I've attached the pertinent parts of the modules and a snippet of the offending code.. were it fails.
J
If you can provide a self-contained example, submit it to Intel Premier Support.
Steve
