29422 Discussions
Possible to use VB Generated DLL in Fortran?
mohanmuthu
I have binary files generated by Delphi application, and have the VB code to read it. Since Fortran's binary format is different, I think of making the DLL in VB and use in Fortran. So, I would like to knowwhether CVF/ifort have options to use VB generated DLL or not.
Mohan
Almost certainly one can use the DLL, but how difficult it would be depends on what kind of DLL it is. If it's a native (non-managed DLL), it's fairly easy. If it's a managed DLL, then one would use the Fortran Module Wizard tool to create interfaces to the DLL routines.
Can you attach a sample DLL here so I can take a look? It would help if you gave me the Delphi or VB declaration of the routine with its arguments and types of arguments.
JohnNichols
Valued Contributor III
CanI suggest that you use a VB application to call your DLL and then pass the data as required to a Fortran DLL, a lot easier and the code exists in the samples. Uisng the Fortran Wizard can waste a lot of time and not end up with a usable product.
Managed DLL's are not a great problem, if yours is non managed you can make it managed using a simple trick from Microsoft - create small small managed app then add your dll to the small one and it will make it managed and then just register it.
JMN
[bash]cd B:UsersJohnDocumentsVisual Studio 2010ProjectsbManagedDLLbManagedDLLbinDebug RegAsm.exe bManagedDLL.dll /tlb:bManagedDLL.tlb /codebase copy "*.tlb" "B:UsersJohnDocumentsVisual Studio 2010ProjectsCPPClientCPPClient*.tlb" erase *.txt cd pause
[/bash]
mohanmuthu
Hi Steve,
Initially I created the DLL with vb6 (unmanaged), but then I thought it would be good idea to start a test problem. Following are the codes. I created "Test_Add.dll" from VB and attached to CVF through Project -> Add to Project -> Files
VB code:
Public
Public Function test_add(ByVal a1 As Integer, ByVal a2 As Integer) As Integer
test_add = a1 + a2
End Function
End
Class
CVF 6.6 code:
Program Test
!IMPLICIT NONE
!DEC$ ATTRIBUTES DLLIMPORT :: test_add
!DEC$ ATTRIBUTES STDCALL :: test_add
!DEC$ ATTRIBUTES ALIAS:'_TEST_ADD@8':: test_add
INTEGER :: i1,i2,i3
WRITE(*,*) 'Enter two integers'
READ(*,*) i1,i2
i3=test_add(i1,i2)
write(*,*) i3
End Program Test
CVF Error:
Compiling Fortran...
..\Test\Test.f90
Linking...
Test.obj : error LNK2001: unresolved external symbol _TEST_ADD@8
Debug/Test.exe : fatal error LNK1120: 1 unresolved externals
Error executing link.exe.
Test.exe - 2 error(s), 0 warning(s)
Class Class1
Oh, you're using CVF...
There are two problems you have. The first is that the name of the routine in VB is 'test_add', not '_TEST_ADD@8'. Yes, the latter would be what CVF would use for a Fortran routine, but VB does things its own way. The second problem is that you don't have an export library to link against - you can't link to a DLL. So instead you could use the Win32 API routines LoadLibrary and GetProcAddress to call the routine. If I recall correctly, CVF has a DLL\LoadLibrary sample illustrating how this is done.
daninraleigh
Steve,
I would also like to call a vb.net managed dll from Intel Fortran. I made the dll "COM visible" and used the Module Wizzard based on the steps mentioned here: http://software.intel.com/en-us/forums/showpost.php?p=135683
Then performed the REGASM step.
In my Fortran program I imported the module with a use statement.
Is this all I need to do to acess the DLL? Or do I need to reference something in the Project's linker settings?
With the following code I get the following error message Unhandled exception at 0x00000000 in TestNetDll.exe: 0xC0000005: Access violation.
[fortran]program TestNetDll use BDataObj implicit none ! Variables integer(4) :: func4 ! Body of TestNetDll func4 = AnInterface_ClearKeyBuffer(NULL) end program TestNetDll[/fortran]
Typically you at least need to call COMINITIALIZE first. But without seeing all of what you're doing, I couldn't begin to guess where the problem might be. I assume that AnInterface_ClearKeyBuffer is a routine generated by the module wizard. You could step into it in the debugger and see how far you get before the error. I am not sure what NULL is here in this context, or how it is interpreted by the routine you call.
daninraleigh
Sorry, I did not follow the directions fully. The accompanying Fortran code does have all of that listed in there.
Again, sorry.
