29542 Discussions
Potential Bug when using Assumed Rank with Unlimited Polymorphic
Lamb__Tripp
There must be something I'm misunderstanding.
I'm attempting to use an assumed rank unlimited polymorphic variable to store data. When I do this I either get access violations or corrupted data. I built a little toy problem to showcase the issue (listed below). The first is an access violation and the second is the corrupted data.
Access Violation
   real, target :: x
   class(*), pointer :: x_ptr
   x = 5.6
   x_ptr => x
   call do_stuff(x_ptr)
contains
   subroutine do_stuff(item)
       class(*), dimension(..), intent(in) :: item
       select rank(item)
       rank(0)
           select type(item) !<--- this is where the debugger crashes
           type is (real)
               print *, item
           end select
       end select
   end subroutine do_stuff
Corrupted Data
   real, target :: x
   x = 5.6
   x_ptr => x
contains
       select rank(item)
       rank(0)
           call do_stuff_inner(item)
       end select
   subroutine do_stuff_inner(item)
       class(*), intent(in) :: item
       select type(item)
       type is (real)
           print *, item ! prints 4.735692598010119E-312
       end select
   end subroutine do_stuff_inner
I appreciate any explanation of what I'm doing wrong. I'm using intel fortran oneapi 2023.0.0.25839. Also to test for posting it does work on this compiler https://www.onlinegdb.com/online_fortran_compiler
andrew_4619
program test
real, target :: x
x = 5.6
x_ptr => x
call do_stuff2(x_ptr)
print *, 'Finished'
contains
    select rank(item)
    rank(0)
        type is (real)
            print *, item
        end select
    end select
subroutine do_stuff2(item)
    select rank(item)
    rank(0)
    end select
end subroutine do_stuff2
    select type(item)
    type is (real)
    end select
end program test
And putting both example in 2024.2 that work also with output 5.6, 5.6, Finished. I suggest you update.
FortranFan
@Lamb__Tripp ,
Try using the latest Intel opeAPI processor v2024.2, perhaps the issue is fixed already?
Also, a variant you can try is where you use the associate-name facility in the Fortran standard to make it easier for the processor and anyone else reading the code to understand which object is what.  See below, perhaps that might help avoid the issue?
Ultimately, you may want to post a reproducer that illustrates the issue with the proper code and the steps you took that led to the problems.
   real, target :: x
   x = 5.6
   x_ptr => x
contains
   subroutine do_stuff( arg )
       class(*), dimension(..), intent(in) :: arg
       select rank( item => arg ) !<-- here 'item' effectively becomes an object of specific rank, not one that is an assumed rank
          rank( 0 )
             select type( val => item ) !<-- here 'val' effectively becomes an object of specific type and kind, not polymorphic
                type is (real)
                   print *, val
             end select
       end select
   end subroutine
end
Lamb__Tripp
The associate-name method did not change any behavior. I'll give updating to 2024 a go. It's just a pain as the code is on a computer not connected to the internet, or I would have already tried that.
I'm not sure what a reproducer is, or at least how it differs from what I already posted.
andrew_4619
program test
real, target :: x
x = 5.6
x_ptr => x
contains
    select rank(item)
    rank(0)
        type is (real)
            print *, item
        end select
    end select
end program test
With Intel® Fortran Compiler 2024.2.0 [Intel(R) 64] that program ran OK in debug
andrew_4619
program test
real, target :: x
x = 5.6
x_ptr => x
print *, 'Finished'
contains
    select rank(item)
    rank(0)
        type is (real)
            print *, item
        end select
    end select
    select rank(item)
    rank(0)
    end select
    select type(item)
    type is (real)
    end select
end program test
