29574 Discussions
Potential bug when calling nested parameterized derived types
WileyOne
Compiler: ifx (IFX) 2025.2.1
OS: Rocky Linux 8.9 (Green Obsidian)
I've found a potential bug at the intersection of parameterized derived types, nesting, and the generic overload. The compiler won't build the code and says, "there is no matching specific function for this type bound generic function reference", but it looks good to me.
If I remove the type parameter, the code compiles. Furthermore, if "generic" is switched to "procedure", it compiles fine.
Am I missing something, or is this a bug?
module Base_Header
    implicit none
    type, abstract :: base(param1)
        integer, len :: &
            param1
        contains
        generic,   public  :: method => method_ ! switch "generic" to "procedure" and this compiles
        procedure, private :: method_
    end type
    type, extends(base) :: extension
        class(base(:)), allocatable :: something
        contains
        procedure, public :: doSomething
    end type
    contains
    function method_(this,x) result(y)
        class(base(*)), intent(in) :: this
        real(8),          intent(in) :: x
        real(8)                      :: y
        y = 2*x
    end function
    function doSomething(this,x) result(y)
        class(extension(*)), intent(in) :: this
        real(8)                           :: y
        y = this%something%method(x)
    end function
end module
WileyOne
I'm following up on this issue. Is someone from Intel able to confirm whether or not this is a bug?
Ron_Green
apologies for the delay - layoffs and summer vacation to blame.
NAG accepts this code.  Gfortran 14.2 gets an ICE.
This looks like an ifx bug but I will confirm with our Standards reps.
Thank you for the ping,.  I will follow up on this report shortly.
Ron_Green
we all agree that this is valid code. The ifx error message is incorrect. Bug ID is CMPLRLLVM-70117
